Question about Sony Playstation 3 (PS3) Console
Ps3 powering problem
When i turn my ps3 on it comes on for about half a second then a white or yellow light then turns red and just flashes
  • 2 more comments
  • mikejones176 Aug 19, 2008
    i turn my ps3 on the green light comes on gose yellow then flashes red
  • fredit24 Nov 12, 2008
    I have this same problem. the light will turn to yellow then green, you can hear the fan kicking in, then a second or two later it kicks out and the red light begins to flash. We just bought it like an hour ago to, so it's not overheated, and it is free from any obstruction. I have tried it on a few different oulets to...same response.
  • Anonymous Jan 16, 2009
    my system has been in the open air for the last 2 years that I have own and have been playing it, suddenly when it's -20 outside and bout 60 inside the house the playstation overheats? how is this possible and when is Sony gonna stop charging people for flaws in workmanship...system overheat suggests poor ventalation which could have been adressed in the design process...wouldn't that make sony responsible for fixing defective units in the same way microsoft did with the 360?
  • dodos21 Feb 14, 2009
    I was online waiting to start a game and it suddennly turned off.When i tried to switch it on the same problem appears.It turnsfrom green to yellow and then blinking red!
  • 95 Answers
This is similar to the red blinking lights of death on the xbox360...it seems your cell processor has overheated resulting in a cold solder joints or worse bridged solder involving the BGA array...The Ps3/WII/XBOX360 all use lead-free solder which tends to to weaken and crack.
I have had some success in fixing these albeit limited. sony charges 150 plus state tax and sends you a refurbished unit.
Posted on Nov 12, 2008
I turn on my ps 3 and it goes green light then after about 3 seconds goes yellow then red.
when i turn ps3 on it flashes a yellow light then the green light comes on it dunt come up on screen and it wont turn off or eject disks
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
It flashes a white/ yellow light then flashes red. will not power on to green.
you need a new playstation i would think you have the yellow light of death my friend google up (ylod) and it will better explain it for you
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Flashing red light. Console fails to turn on.
Follow all 6 videos and your PS3 will work again. and it wont cost you $150 with sonys Refurbish program
Jul 25, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
My Ps3 isnt starting, light turns green then changes to yellow
this is the ps3 equivilent of the xbox360s red ring of death error, sorry to tell you but that means a serious system error has killed your ps3 its unfixable and you will have to send it off for a replacement
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
How to fix blinking red light on my ps3?
You should open up the PS3 and use compressed air to dust it off. Take a look at the thermal paste to make sure it isn't dried up! PS3 Flashing Red Light The Ultimate Solution
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
