Question about Maytag 21.9 Cu. Ft. Bottom-Mount Refrigerator - White
Maytag Model MBB2254GEW, bottom freezer: intermittently freezes and do not always feel cool air coming through the fridge. This is on and off for the last few months, where we find ice cubes all melted and food de-thawing. Also the unit keeps making buzzing and clicking sounds every few minutes.
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 24, 2011
Maytag performa fridge model# ptb1753grw freezer freezing up and the fridge not getting cool. i defrost freezer remove the ice then the bottom fridge gets cold again. but it keeps freezing up again.
You have one or more of your defrost components that are bad. Defrost heater, defrost thermostat, and defrost timer or board depending on model are the 3 components.
Nov 02, 2017 | Maytag Refrigerators
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Refrigerator portion on top does have cooling but freezer on bottom works fine. I have read that the cooling all happens in the bottom and a fan transfers cool air to the the top.
if the fridge part is cool and freezer is fine what problem are you having?is the fridge not cold enough? a common problem with bottom mount freezers is the freezer door doesn't get closed all the way,warm air enters the freezer mixes with the zero degree air and freezes up the air ducts,when you open the freezer door you should hear the fan blowing,if it is check the ceiling in the freezer to see if ice is on it,check the packages for frozen water droplets and stick your hand in the fridge where the air ducts are to see if you can feel cold air blowing into the fridge,if you can't feel air blowing into the fridge,unplug it,open the freezer door,remove the top basket and remove all the food out of the bottom basket,with a hair dryer blow into the back wall into the vent holes and melt out all the ice in the ducts,you'll see water dripping down through the vent holes,when the water stops dripping plug it back in and see if the fan is blowing the air into the fridge.also you can remove the bottom kickplate and you should see a tech sheet in it,read it and it will tell you how to put the machine into defrost,it will stay in defrost for like 20 minutes,you can do this instead of unplugging it, there's a heater that comes on behind the back panel in the freezer,this can help you melt out the ice but if it seems to hard to do just unplug it.
May 25, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My Kenmore side by side Refrigerator Model No. 253.55679403 will not freeze or cool, ice is melting and food is thawing. Light comes on and I can hear a fan or something, but I'm n ot sure. Can you help?
if you hear a fan in the freezer section when the door is open. feel the bottom of the fridge for hot air blowing. if you dont feel any hot air at the bottom, the condenser fan is the problem. if you do feel hot air then you have a defrost issue.
Jul 24, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge is not cold but the light will turn on...
Hi, Has it been 30 minutes since you turned it back on? It might be in defrost cycle. Please let me know I can assist you further.
Vic
May 30, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
Refridgerator not cold but freezer is freezing fine.
This model uses the cold air from the freezer, defrost complet unit for 24hrs, turn back on and it should work ok. Regards Advisor
Aug 19, 2007 | Whirlpool ET0WSRXML Top Freezer...
Maytag 21.9 Cu. Ft. Bottom-Mount Refrigerator - White Logo
250 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
