Question about Sony UWABR100 Network adapter USB 80211b 80211a 80211g 80211n Pre80211n
Trying to connect my wireless adapter. what is the wpa key
Use MAC Filtering. I had a prob with power failures here in Florida and the encryption setting had to be re-done every-time. So go into all devices and copy down all your MAC addresses and then pop them in your wireless router and poof only those Mac's can access the access point. I think there are weasel ways around this but most people including myself will not take the time or effort to steal bandwidth for all that trouble and you can always see if you have hitchhikers via the router. This was my easy solution to encryption. Okay I here them yelling now" but my info is not safe while it flies through the air to my router" SO WHAT! unless your doing CIA work you don't have to worry. and most PW fly through the air encrypted already, so there..lol
Posted on Oct 19, 2011
  • 38 Answers
A WPA key is an encryption key for wireless networking devices. If you want to use a wireless router, you would need the WPA key that is setup in the router itself, in order for you to connect to it. You can see the WPA key on the security screen of your wireless router. Hope this helps.
Posted on May 24, 2011
2 Suggested Answers
webmaster21
  • 803 Answers
SOURCE: My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
Posted on Sep 24, 2009
Lan card is not connecting wireless connection available showing full signal but not connecting.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jun 15, 2011 | TP-LINK TL-WN350G, 54Mbps Wireless PCI...
Hi guys, I have an Samsung LED TV, UE46B8000. When I tried to connect my samsung wireless lan adapter, the menu for security key displays only 6 uppercase letters, from A to F. My security key has more...
Right now the security on your LED is set to 64 bit wep - now you need to change security on LED to wpa/wpa2 and that will solve your problem .
Advisable :if you can make sure what kind of security is been enabled on your wireless router (wep 128 bit or wpa/wpa2 ) that will be more helpful for you to select the security on led - give a try with wpa/wpa2 .
Oct 04, 2010 | Samsung WIS09ABGN (8808993304486)...
I have a DIR-615 router that I have no problem connecting my laptops with internal wireless. However, trying to connect my desktop with a DWL-G620 Wireless Adapter. It detect the network but will not...
The WPA key is the encryption key that is configured in the router's wireless settings and the wireless cards in the laptop and desktop needs to be configured with this encryption setting to allow the laptop and desktop computer to communicate with the router.
You can view the encryption settings in the router's wireless settings or on the laptop's wireless card settings and then apply these encryption settings to the desktop's wireless card (ie. the SSID and the WPA encryption).
Nov 15, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
I have plugged in a wireless adapter for the 360 but...
A red steady light on the adapter means it is ready to be connected to a wireless network. If it fails to connect then the WPA key is not correct.
WPA automatically changes keys on a frequent basis for security purposes. So you need to take note of the SSID (wireless network name) and the Wireless security settings (WPA and passphrase) from the wireless access point/router.
Once you have the wireless network settings on the access-point/router, go to the System area to enter those settings.
If all settings are correct, exit the System area. Your console should now be connected to your wireless network.
Hope this helps! Good luck!
Oct 01, 2009 | Microsoft Wireless Network Adapter Xbox...
Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Wpa encryption for wireless g adapter
This is a known issue . A WPA encryption does not work for G adapters to N routers. Try to reduce the encryption to WEP and check . Im sure that will work.
Sep 06, 2009 | D-Link Computers & Internet
WIRELESS CONNECTION PROBLEM
Have you configured your wireless adapter with same WPA key that you had set on the wireless router?
Do you detect other Wireless routers in your area and are they using the same wireless channel as your router?
If so change the wireless channel on your wireless to an unused wireless channel to avoid interference with other wireless routers.
Apr 19, 2009 | Averatec 3200 Notebook
Belkin wireless adapter thinks router is WEP but its WPA
Try reseting it, if that doesnt work, then tell me, so I can help you step by step.
Jan 11, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Sony UWABR100  Network adapter  USB  80211b 80211a 80211g 80211n Pre80211n Logo
286 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
