2 GB Certifeid Hi-Speed USB Flash Disk with cdrking packaging ( VM04L-2G)
  • 27,725 Answers
If you are having problems with this usb drive
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver hope this helps
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on May 24, 2011
  • Brian Sullivan
    Brian Sullivan May 24, 2011
    click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
LaCie Rikiki Hi Speed USB 2.0 320 GB Hard Disk repair
Check Device Manger and Disc Management. Best I can do with translation problem. Good Luck
Aug 27, 2012 | LaCie Petit Hard Disk hard drive - 320 GB...
Im forget my passwor, how format my flash imation 2G
Hi Marchohama,
follow these steps :
1) Insert your drive in any USB of your PC/Laptop
2) Go to "My computer"
3) Find the drive name of Kingston drive
4) Right click on it, a menu will show
5) Click on "Format" on that menu
That is all
Mar 16, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Samsung Pleomax Ultra-Portable UHD-12G - hard drive - 12 GB - Hi-Speed USB. I think the autorun was deleted off of this flash drive. The computer does not see it at all. There are no yellow x's under...
This could be an issue with assign the drive a letter:
1. Right Click on "My Computer" (might be called computer)
2. Left click on Manage
3. On the left click on "Disk Managment"
4. Check to see if the 12GB USB drive is showing up there if it is then right click on it and assign it a drive letter.
If the USB does not show up in "Drive Management" then try another USB port or another computer to test to see if the USB drive shows up.
Hope this helps
Mar 07, 2011 | Samsung Pleomax Zirex UHD-12G 12 GB USB...
I bought new hp usb flash drive 4 gb when i go to
you can try getting a flash for your bios to see bigger drives it is probably a size limitation in bios what operating system are using and how old is the computer
May 09, 2010 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
Pen drive is not working
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
Dec 14, 2009 | Kingston Technologies 512MB DataTraveler I...
Formatting (FAT) 2g drive left drive with only 735Mb. How do I format for the full 2g? Thanks
what device did you use to format your flash drive? is it a camera or PC?
now try to insert your flash drive in a usb port of a PC running windows vista since it has a better disk management tools. now format it from there using FAT32 file system to regain your disk space. you can also try windows xp
Oct 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flashdisk 1 gb to be 8 gb
2. Format
Feb 19, 2009 | iLO (2 GB) MP3 Player
How to remove write protection from flash disk
hi, i'm from indonesian i have a problem about flash disk USB2.0 1 gb. can u help me i have flash disk 1 gb to be 8 gb (not upgrade) it change it self "i don't know why & can't be to format & delete. i want to default be 1 gb to be a normally.
sorry of my bad english,,thank's
Jan 09, 2009 | iLO (2 GB) MP3 Player
2g attache optima pro black/amber went to write protected...how do I fix it?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Dec 10, 2008 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
WD3200ME-01 Passport size diskspace problem
To format the drive to allow files larger then 4GB: Open up My Computer, Right click on the Western Digital Drive. Select Format from the list. Under file System, select NTFS. Under format options Check Quick Format. Click Start to format.
Warning! Formatting will delete all data and files on the drive. Make sure to transfer all your files to another drive before preforming a format!
Jul 03, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
