Question about Lowrance LCX-20c GPS Receiver
What Dimension mmc card do I need for a lowrance lcx-16ci? and do you need the cards in order to get a picture. I bought a boat with this gps and it is not working properly
  • george raynor May 24, 2011
    you answer was very helpful but I am not sure how and from where do I upload information on the mmc. I dont have any kind of slot on my computer for the mmc.
    thanks george
    thank you so much jas247 for your detailed and timely responses. you saved me tons of money because I would have probably bought another GPS. this was the first time I used this site and I am sold. thanks again.
    george
  • 844 Answers
Welcome to FixYa!
Standard MMC card will fit in to your GPS receiver. The manufacturer recommends 8MB or 16MB capacity only which is I believe is for efficiency purposes. If I am not mistaken, the lowest capacity MMC card available today is 128MB and I think you should go for it.
Yes you do need to have the MMC card when taking pictures since your device does not have internal memory for pictures.
You also need the MMC card for storing Maps and other data.
Here's a sample picture of the MMC Card.
Thank you for using FixYa. Have a great day. Jas247
Posted on May 24, 2011
When turning on the Lowrance the depth indicator will only register 0.0 and continues flashing the number. The Lowrance is a LCX-17M. We tryed the Lowrance on another boat with a working transducer...
here is the link to your the lowrance web site. the trouble shooting guide says that if you tried to it on another boat than you might need to take it in for service. but there is a section that explains how to do a soft reset on the unit. you might try that.
http://www.lowrance.com/en/Support/Troubleshooting-Guide/Depth-Reading/
please rate and comment on your experiance with fixya.
Aug 15, 2008 | Lowrance LCX-18C
Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Apr 20, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Need map updates for GPS
Dependant on the type of unit you have, you can order MMC or SD cards from several companies. I have used Navionics with much success. They have a buy-back program where you can get a discount towards the latest cards when you turn in your old ones. Also, if you have a memory card device, you can access tons of lakes directly from the Lowrance website. Then save to acard and load into you boats unit.
Triton72
Mar 25, 2009 | GPS
I have a lcx 28c hd fish finding sonar and mapping gps
I've had several similar units, and used them with Navionics HotMaps Premium series chips. You must select Menu. The "Browse files" to access the MMC card option. Once the selection screen opens, choose which card or file you want.
FYI...All of Lowrances HD models come preloaded with pretty much every major lake and river in the US.
Lemme know if this helps...
Triton72
Mar 23, 2009 | Lowrance LCX-27C GPS Receiver
Need a manual for my lowrance lcx marine gps combo
You're in luck! Visit => http://www.lowrance.com/en/Downloads/Manuals/
There are 3 manuals (pdfs). The first is the manual, the next two are addendums.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-15MT_0133-49.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-70_add_031402.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-71_add_032802.pdf
Please leave feedback. Thanks in advance.
Jan 03, 2009 | Lowrance LCX-15MT GPS Receiver
Turning on my Lowrance LCX 111HD fish locator creates static with my ICOM M502 VHF Marine radio.
Hello LJones0455. From your detailed attempts there are few options. Position the transducers one foward one aft. Connect the negitives of the battiers to the boat still route both positive & negitive wiring to all devices. Check the continunity of your transducers include flexing while ohming. Let me know of the results.
Oct 07, 2008 | Boating
Lowrance LcX 27C
You need to get a MMC card for it to show Canada.
Jul 02, 2008 | Lowrance LCX-27C GPS Receiver
Lowrance LCX-16ci - screen's gone out
I have a working unit with a bad antenna. Interested?
Davidwcantrell@comcast.net
Apr 09, 2008 | Lowrance GPS
Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Mar 15, 2008 | Lowrance LCX-19C GPS Receiver
Lowrance LCX-20c GPS Receiver Logo
105 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
