Question about Texas Instruments TI-84 Plus Calculator
The buttons on my TI-84 plus are not working except for the ON button. I got a new set of batteries but it still says"Your batteries are low. Recommend change of batteries." when I turn it on, when I press ON again to get rid of the message it shows a blinking square in the top left corner, afterwards, I can only wait for it to turn off or remove the batteries.
  • 4 Answers
SOURCE: None of the buttons on my TI-84 Plus calculator are working.
is the cursor the graphing cursor or the normal typing cursor?
Posted on Feb 22, 2008
SOURCE: error message for TI-84 Plus
Try and resolve this issue by re-installing the calculator's operating system using the TI OS Downloader. To do this, please follow the steps listed below. Be sure you have fresh batteries in your calculator.
1. Download the OS 2.43 file to your computer (preferably the desktop).
2. Open the TI OS Downloader by going to Start>>Programs>>TI Tools>>TI Connect>>TI OS Downloader. If you do not see TI OS Downloader, you may need to install the latest version of TI Connect. You can download a free copy from:
www.education.ti.com/downloadticonnect
3. From the main screen, select your calculator and cable type. Click "Next" to continue.
4. From this screen, locate the OS 2.43 file by clicking on the yellow browse folder and navigating to the location where you downloaded it. Double-click the OS 2.43 file to select it.
5. Remove one triple A battery from your TI-84 Plus. With the battery removed, press and hold the [DEL] key while you re-insert the battery.
6. You should see a "Waiting..." message on the screen of your calculator. If so, disconnect the USB cable from your computer, re-connect it and then click "Start Download". This should begin the OS transfer process.
Posted on Aug 20, 2008
rockitman187
  • 2559 Answers
SOURCE: Can't find the % button on TI-84 plus :(
Just hit the 2ND key and the 0 (catalog key)scroll down to percentage or just divide the answer by 100.
Please rate this a fixya
Posted on Feb 13, 2009
  • 21 Answers
SOURCE: TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Posted on Mar 02, 2009
  • 192 Answers
SOURCE: Find the antilog on the TI-84 Plus for finding pH in chemistry problems
I'm not specifically familiar with the TI83 or TI84 but I've used a lot of TI calculators in my time, so I'll give it a try. If your trying to find the antilog of a number in base 10 enter the number and hit the (10 to the X) button. If you're trying to find the antilog of a number in in base e (natural log), enter the number and hit the (e to the X) button.
Posted on May 29, 2009
Unfreeze ti 84 plus calculator
hi
try pressing the clear key if that don't work than reset the calculator by pressing the reset button or remove the the batteries from it for one minute than put it in amd press the clear button and you should go to go however you may to check and change certain setting lile the degree setting i.e. radians to degree and fix to floating notation and other important setting as well.
I hope this helps.
Aug 27, 2014 | Texas Instruments TI-84 Plus Silver...
Up and down arrows on my ti-84 work as left and right arrows on the main screen! how do i fix this?
Remove one of the AAA batteries.
Press and hold CLEAR while reinstalling the AAA battery.
Continue holding CLEAR button and press ON.
Release buttons and press CLEAR again.
Feb 03, 2013 | Texas Instruments TI-84 Plus Silver...
My TI-84 calculator isn't working. When I press the "ON" button, sometimes it would respond, but most of the time it doesn't. The screen just remains blank. I've changed my batteries...
try taking out the triple A batteries and leaving the calculator to sit with them out for a minute or so, replace them and check if it's fixed. If that doesn't work you can do the same, but take out the small button back up battery as well. If you're still not having luck you should call ti cares (800-842-2737) they're usually helpful.
Aug 09, 2011 | Texas Instruments TI-84 Plus Calculator
If Texas Instruments TI-84 Plus Calculator hangs on screen "RAM CLEARED" , what should I do?
You should try a few different things:
1) Press the Clear button
2) Press the On Button
3) Remove and replace the batteries
If the final step does not work, you should also remove the backup battery. This is located UNDER the AA batteries. You will need a small screwdriver to remove the cover. Replace everything and turn the calculator back on.
Feb 12, 2011 | Texas Instruments TI-84 Plus Calculator
TI-84 Plus Silver Edition not responding!
what helped for me is leaving it w/h any battery's (no backup battery either) for a few days. Now miraculously it works!
May 06, 2010 | Texas Instruments TI-84 Plus Silver...
My TI-84 Plus Silver Edition stopped working
That actually is a result of water damage. You probably need to replace it, or see about getting it taken apart and dried if the water damage was recent. DO NOT take it apart yourself. Go somewhere and ask if that is possible.
Jan 28, 2010 | Texas Instruments TI-84 Plus Calculator
TI-84 Plus with water damage
I had the same problem but its best to first just dry it out and with a hair drier at low. Forget about openning it up i couldn't get mine open either. Let it sit for a day and then take the batteries out and press the on button for 30 sec. then take new batteries and put them in and it should work.
Jul 14, 2008 | Texas Instruments TI-84 Plus Calculator
My TI-84 Plus always turns off randomly
Try resetting the calculator to what I will call the "factory settings", do so by holding the "CLEAR" button, and while holding it, take out the batteries, then put them in
Apr 18, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
225 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
