Question about Globe Electric Globe Indoor/Outdoor Lights Timer Kit, 2-Pack #82428201
Ok i got a timer from glode but i dont know the model. so what can i said i got a push button in front and when i push it a letter f with the number 0 to 9 appeares. after that the letter r and d whit the number 0 at 9 too. i want to program it to stop at 8 pm and bigging too run at 6 am. so can you help me to program it please???
1) Good clues on description: It's a dawn-to-dusk timer.
F is always ON or always OFF.
O is always OFF or always ON.
1 thru 9 is timer turns ON at dusk and turns OFF 1 to 9 hours later.
D is ON at dusk and OFF at dawn.
R is probably timer turns ON immediately then turns OFF 1 to 9 hours later.
Best guess: At 8 pm you press button until R9 displays, and then timer will turn ON each day at 8pm and OFF each day at 5am.
2) Open following links to find same-similar timer and check which one matches your product.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13660
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 24, 2011
My neff oven b1322.1 is showing c03 code since moving , I now can't set the timer and clock etc can anyone help to solve this?
The C03 error indicates that the timer button is stuck or not responding. Check if the buttons can move freely; you may need to remove the rubber cover by prying it up. If the buttons move freely, sometimes the error can be cleared by unplugging the oven (or turning the unit off at the circuit breaker) for several minutes (up to 30 minutes). Turn the power back on. Then press and hold the Timer button for more than 180 seconds (3 minutes). Some people have reset the timer by setting the function selector to "interior light on" instead of pressing and holding the timer button.
If none of these actions work, then the timer clock needs to be replaced. If you add a comment with the full model number of your oven, I may be able to give you the part number. NEFF doesn't list a B1322.1; there are several B1322N1 models. There will be addition numbers in the model number and there may be some extra letters as well. See http://www.neff.co.uk/store/spare-parts to get a picture of where the rating plate is for your unit. That will have the full model number.
I hope this helps.
Oct 01, 2016 | Neff Ovens
Samsung washer front letters dissapear
Just use a marker to put a dot next to the start button and another mark to indicate different settings. You can look up the settings online
Oct 14, 2013 | Samsung WF337AA Front Load Washer
WHERE IS OVERIDE BUTTON
It depends on the timer.
On some programmable on-wall timers, you push the little door and that is the manual override.
On other models, you open the door and push the on-off button, or another button.
On some models, there is a slide switch on the front of the timer: slide the switch to ON
Nov 09, 2010 | Woods InWall 7 Day Digital Programmable...
Whirpool WED5820SWO after two or three loads of running fine, the dryer will not start when the button is pushed until you jiggle the timer knob and sometimes the dryer will start in Timed dry and then...
If you're going to purchase parts for your appliance you are going to need to know the correct part number to ensure you get the right part. The part number for a new timer for the model number you provided is 8566184. It can be found on line at appliancepartspros.com for about $55. You can also try the following appliance parts websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
Some of these sites also have helpful exploded view diagrams to assist you in locating the parts you need. Your timer is listed under the "Top and Console Parts" heading as item 21.
To replace, make sure your dryer is unplugged. Remove the back panel of the operator console and the timer knob. Either use a digital camera or write down the correct location of all the wires. They are are color-coded and marked on the timer, but some replacement parts can differ slightly in design. HINT: An easy method is to remove the screw(s) that hold the old timer in place and allow it to hang. Then, swap wires one at a time from the old timer to the new one.
If you have any questions, please let me know. I hope this helps you.
PS Your model number is actually "WED5820SW0". The last digit is a "zero" vice the letter "O".
Feb 17, 2010 | Whirlpool WED5820S Electric Dryer
Number an letter combo won't change back to letter
Sounds like you have number lock on. To turn this off you'll need to hold the function (Fn) button and press number lock. I'm not sure which is the numlock button on your model but it looks like on other models it's F11. Make sure you hold the Fn button down until you've pressed Numlock though or it won't work.
Apr 29, 2009 | Acer Aspire 5500 5570-2609 Laptop
I need a printout for instructions to set an Intermatic EJ 500C digital wall switch
I have a intermatic house timer to turn on and off the outside lights We moved in 5 years ago to this house. One evening somehow the lights did not turn on or turn off when programed. I accidentally reset the system by pushing the reset button instead of the on / off button. I dont have a model number of the timer to look up, maybe you can tell me where I can find it on the device? or general instructions on how to set the system to go on when the time is set and of . I was hoping to see if I can find a model similar to one I have. I saw one close but I dont know its the same or not.500c or maybe a model 10 years ago plus. By the way it has a battery conpartment using a single AA battery. The best description I can give you is its white in color...rectangle has a display screeen on top of the unit....and has 6 soft push buttons ....3 on to , 3 on the bottom....top row of buttons has MODE ON/OFF EVENT...RESET the bottom row has DAY...HOUR....AND MINUTE..Please advise
Apr 05, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
LEA30AW AMANA DRYER TIMER SWITCH CONNECTION PROBLEM..
I don't have a diagram but it is possible the the first letter of many of the colors is on the plastic around the screw connectors. Have a look. Good luck.
Dec 21, 2007 | Amana DLE330RAW Electric Dryer
Globe Electric Globe Indoor/Outdoor Lights Timer Kit, 2-Pack #82428201 Logo
159 people viewed this question
Top Globe Electric Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Globe Electric Hardware and Accessory Expert? Answer questions, earn points and help others
