Question about Coby DVD765 Theater System
My center speaker is humming after i turn the tv on.
    Problem Solver:
  • 5 Answers
If you center speaker is humming, you when you turn on your TV, you may have the audio signal over amplified and the hum may be coming from your TV itself. Try moving the speaker further away from the TV or the amp further from the TV and see if it solves the problem.
Posted on May 24, 2011
Tv and speakers buzzing noise
If the hum is a low note continuous hum, its at 'mains' frequency. The power cables to the unit (or inside it) are getting too close to the cables that carry sound signals to the center speaker. The mains power naturally hums and if mains wires are near to audio kit wires they pick up this sound and play it through their system/speakers. Check the wires to and from it make sure the connections are good and firm. Seperate these wires by at least one inch from any power cables, use tape to hold them down and away from each other.
Dec 15, 2013 | Bang and Olufsen Audio Players & Recorders
How do I GET THE HUMMING SOUND OUT
Hello
The audio output section of your tV has the fault. The main reason for HUM on output, is due to a shorted audio output IC. Never use the TV, until the fault has been rectified. Prologed use at this state will damge the speakers, and speakers may also be replaced. OK.
Feb 02, 2012 | Sansui Televison & Video
ONE SPEAKER HUMMING NO SOUND JUST HUMMING AND HISSING
Hi, sounds like your TV speaker went bad and it needs to be replaced, if you are still under warranty then you should call a repair center and they will send a tech to your house to replace the speaker for free, check localy to see who is closest to you or you can call Sears, Walmart or Bestbuy and request repair, otherwise you will need to pay for the cost of speaker and labor which typically would be under $100 for that issue... best of luck
Jan 29, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Loud hum when I turn on power from the speaker
Disconnect the device (amp or TV) that is feeding the speaker system. Turn on the power and see if there is still a hum. If the hum is no longer present, then the hum is most likely from the source.
If the hum persists, most likely the power supply has failed, or the output section has a short. You should contact the manufacture for support. They will most likely recomend that you give the unit in for service.
Jerry G.
Feb 09, 2009 | Coby 5.1 Channel DVD Player with Home...
MY NEW SAMSUNG LN32A550 TV HAS A HUM FROM THE SPEAKERS
In most cases it's the Cable issue. Either bad Cable Box or the Wires are not grounded properly. Disconnect the Audio Cables or the COAX cable from the Cable Box and see if the Humming noise goes away.
Jan 31, 2009 | Samsung LN32A550 32 in. LCD TV
Sanyo LCD TV speaker hum at low volume
if the hum is only on the speaker s and not the headphones and you have tried the ground and ferrites I would suggest it is a amplifier problem. Either take it back for refund or plug a small set of amplified speakers into the headphone jack. i.e computer speakers or such- that will at least tell you if it is indeed the amplifier.
Feb 27, 2017 | Televison & Video
Loud humming noise from new hdtv
hello, the speakers are fualty or have a shorted connection if they came with the tv contac your seller and arrange for a replacement imediately dont wait. since they are giving you feedback dont use them they may cuase other fualts in your tv, any component thats cuases hum or noise when pluged into the tv should not be used at all.
one important thing is to have a grounded plug this also may cuase fualts down the line,
if posible get a power line conditioner or ups (uniteruptable power supply)
flat panels are very over protective you dont want the tv to start blinking. since flat panels have built in protection circuts any slight short or fualt may cuase the wide screen to go into circut shutdown mode and this will cost you more if the speakers create a short in your audio circut it may damage your widescreen internal boards and cuase a system shutdown circut (red light flashing no picture)
contac your sellers site let them know your speaker are cuasing a loud hum
and that you will need the speakers replaced these are definitely fualty
if you dont have any coverage or you got the set as is then dont take any chances use other speakers.
if you are electronically inclined you can open these up and find out whats wrong with them internaly it may be a loose connection, since opening up the equipment may void your warantee contac the store first see what they say..
good luck happy holidays
Dec 10, 2008 | Hannspree Televison & Video
Humming noise when turned on
Annebatiste:
Humming almost always comes from DC supply problems.A leaky SCR [silicon control recitfiter] transistor [used in a/c to dc power supply], leaky Capacitor [large metal type for heavy voltage\current], bad or value changed bias for SCR transistor, value changed filter resistor and loose transformer[Xformer] that the coils INSIDE vibrate sending a radio frequency [R\F] SIGNAL (like a radio station) into the audio amp section or right into the speakers causing the hum.
Check entire power supply, all filter capacitors, coils, chokes ,transformers (somtimes used to push signal into speakers)
Jun 28, 2008 | Samsung DLP HL-P5663W 56" TV
Coby DVD765 Theater System Logo
222 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
