Question about OfficeMax 0M96431 Shredder
Shredder OM96144 jammed then stopped working. Blew a circuit. Cleaned out the back of unit. Plugged in again several times, no luck.
  • kashe156 May 24, 2011
    Also blew a fuse
4 Suggested Answers
SOURCE: Shredder motor seems jammed
The teeth on the plastic gear that turns the massive metal gears that turn the shredder teeth is probably stripped and needs to be replaced, if you can find the part.
Posted on Jul 01, 2007
  • 45 Answers
SOURCE: OM96144, The Door Open light will not turn off, so
It sounds like the safety switch on the door has failed.
You will need to have the safety switch on the door replaced.
There is another option but it is not recommended as it will bypass the doors safety mechanism and requires the switch wires to be cut and connected to complete the circuit.
You should never play with anything electrical as it can cause serious harm and / or death.
So I would recommend you have a qualified repairer look at it.
I hope this helps.
If you have any further questions please let me know.
Best regards,
Dave
Posted on Nov 23, 2010
Testimonial: "Thanks. I'll just replace the whole unit."
dcramer531
  • 1654 Answers
SOURCE: I have an OfficeMax paper
Do you have any lights? If not then you will need to replace a blown fuse on the circuit board. The fuse is soldered into the circuit board. Check the fuse with an OHM meter for continuity. The fuse is 6.3 A miniature pigtail, You have to solder in a fuse holder and regular size fuse unless you have a source for the pigtails. If you have lights and can hear a motor then chances are, the overfeed caused the teeth of the gear that operates off of the motor to break which is not uncommon. How old is the shredder, is it possible to return it under warranty? Have you made sure that all the paper is out of the teeth and not blocking the sensor? sometimes it can get quite hard to remove all the jammed paper. You will have to take the cover off the shredder hear to acces the circuit board, might get lucky and find this model ahs an easy change fuse but most do not. Also have you checked it with another outlet to make sure the outlet fuse did not blow?
Pigtail fuses should look like the ones in the picture provided.
Posted on Aug 18, 2011
My ativa 12 x-cut paper shredder runs for 1/2 sheet then stops. how would you identify problem and fix it
The sheet detector may be malfunctioning. Your shredder may have to be cleaned to restore proper operation. Mine gets clogged periodically and has to have the bin removed so the entire shredder can be turned upside down to perform dental hygiene on the teeth. Paper shreds even get jammed in the spaces between the teeth. Flossing doesn't help!
Mar 07, 2015 | Shredder Office Equipment & Supplies
My shredder won't power on. It is not overheated.
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Aug 11, 2013 | Staples Cross-Cut Shredders; 10 Sheet
My office max OM01287 Shredder has no power to it is there a rest button it worked just fine the last time I used it and now there's no power?
Double check the safety that stops the shredder when it is full sometimes that switch gets jammed with cut paper. Also make sure the top of the shredder is level and properly seated back on the base unit. The shredder feed area may also need to be cleared there may be a staple or just paper jammed into this area as well, make sure the unit is unplugged before trying to inspect and clear and part of the shredder
Jan 16, 2013 | Office Equipment & Supplies
Shredder doesn't shred.
Shreader wont cut will reverse ok
Dec 17, 2012 | Office Equipment & Supplies
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    Carriage Jam on my HP Officejet 5610v All-in-One printer
    If I move the carriages to the center of the bar they slide on (would be the center of the paper) and close everything it seems to re-load, I've had to do this several times over the last few years and so far it always works
    Feb 09, 2010 | HP Officejet 5610 All-In-One InkJet...
    Runs continuously when in the on position.
    there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
    Dec 18, 2009 | Fellowes DM8C Cross-Cut Shredder
    I have an Omnitech OT-535BL paper shredder. It got a jam, I cleaned the paper out but it still wont work. It sounds like it is turning on when I plug it back in but it wont go.
    This unit can also overheat and automatically shuts down when it does; to be thorough--simply unplug, empty the wastebasket, turn upside down, remove any remaining paper from blades, plug back in, and leave it alone for 30-60 minutes. Try again.
    It's not an industrial shredder and has a low daily capacity, designed only for small office use.
    May 02, 2008 | Computers & Internet
    Motor reverses
    took the circuit board out, blew dust, reconnected all the wires then plugged the unit back in. it is working ok
    Dec 12, 2007 | Dahle 20606 Shredder
    OfficeMax 0M96431 Shredder Logo
    113 people viewed this question
    Top OfficeMax Office Equipment & Supplies Experts
    ROCKIT957
    Randy Schumann
    Randy Schumann
    Colin Stickland
    Colin Stickland
    Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
