Question about Frigidaire FEF336BC Electric Kitchen Range
Is it normal for my frigidaire stovetop to have a low clicking noise while cooking on the right front surface..it sort of goes on and off every 15 seconds.. its the first use. thanks Karen from Costa Rica
  • 521 Answers
SOURCE: burner on range will not turn off
  1. all these problems are given in the link below and the solutions with diagram is given in it
  2. http://www.applianceaid.com/micro.html
  3. A common flow chart for microwave repairs
  4. A breakdown of a newer counter style microwave
  5. Door switch caution and repair help
  6. How can I get at the handle screws on my microwave to replace the handle? This has a common GE style microwave picture to help you.
  7. How to install a common over the range microwave
  8. Important Disclaimer
  9. I set something on fire in my microwave and now it is dead...help!
  10. My GE OTR ( Over The Range ) microwave is running but will not cook
  11. My Frigidaire microwave is flashing a fault code in the display...what's up?
  12. My GE microwave is flashing a fault code in the display...whats up?
  13. My Panasonic microwave is flashing a fault code in the display...what's up?
  14. My Sharp microwave is flashing a fault code in the display...what's up?
  15. My Whirlpool microwave is flashing a fault code in the display...what's up?
  16. My microwave light bulbs burnt out...caution!!
  17. Ohm testing an capacitor
  18. Some common Microwave FAQ
  19. Some common components and how to check them with a ohm meter - like magnetron, high voltage transformer, high voltage capacitor, door switches and high voltage diode.
  20. Stainless Steel Cleaning
  21. Sparks from inside the oven area....why?
Posted on Aug 27, 2008
  • 223 Answers
SOURCE: Can an SD card for
As far as I know an SD card is an SD card in any country. If that is what the satnav takes then it should work no problem. Hope this helps.
Posted on Oct 05, 2008
Big Poppa Ma
  • 302 Answers
SOURCE: how to reset maintenance service indicator 2008 ML 320 CDI?
you could try unpluggin the negative battery cable from your battery for five minutes so it resets the computer
Posted on Dec 06, 2008
  • 105 Answers
SOURCE: The right front element will not heat properly on
Without a proper model number I would say you need to replace the element or the infinite switch for the element. Best off to call a reliable repair company such as Sears.
Posted on Jan 31, 2010
bily8888
  • 14 Answers
SOURCE: necesito descargar el mapa para costa rica
mapas de argentina visiten www.mapeo-gps.com.ar
Posted on Apr 06, 2010
Frigidaire ceramic stovetop burner not working
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
Aug 30, 2014 | Cooktops
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
I am hearing a low clunk noise from right front
could be cv booth starting to worn out
Jun 01, 2010 | 2003 Honda Odyssey
Steam is shooting up from stovetop when I'm using the oven, along the back, right side. Is there some kind of seal that can be repaired? Or does the stovetop need to be replaced?
this is normal,the stove must have this feature in order to cook properly and keep your food from tasting like last years turkey
Mar 06, 2010 | Ovens
I have a Frigidaire over the stove microwave that pops/arcs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 15, 2009 | Frigidaire GLMV169D Microwave Oven
My Jenn-air stovetop won't stop sparking. It goes
yes it causing a false ground
giving the ignitor a false gorund will make it fire
it should calm down or you can turn the flame on and let it dry
Oct 09, 2009 | Cooktops
The right front burner won't heat
The switch probably failed. Remove power. Take off the top rear cover and inspect the switch for signs of discoloration (burned or brown areas). If looks OK then maybe the element failed.
May 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FEF336BC Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
