Question about Dishwashers
How to hook up the drain hose on a Kitchen Aid Whisper Quiet ultima that is proabably 3-4 years old?
  • 530 Answers
SOURCE: Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Posted on Apr 14, 2009
  • 234 Answers
SOURCE: Have a kitchen aid whisper quiet dishwasher...will
There is probably a problem with your drain hose being plugged or the drain valve/solenoid is jammed or defective.
You would need to check these two problems and repair or replace parts.
Posted on Apr 17, 2009
  • 246 Answers
SOURCE: Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Posted on Feb 25, 2010
tbreeze47
  • 3083 Answers
SOURCE: Kitchenaid Superba Whisper Quiet Ultima:
Not familiar with that model, but one time I found a baby sock jamming the water outlet in a dishwasher, so check to make sure there's no foreign object blocking any exits. Other than that, I suspect it will need to be serviced, or at least taken apart for further inspection.
Posted on Mar 13, 2010
  • 949 Answers
SOURCE: My kitchen aid whisper quiet
The flashing clean light is an indication that the water did not heat properly. Follow the link below to some instructions I put together that will show you how to reset the control so you can use the dishwasher again and what may have caused the error. Let me know if this is helpful.
Clean Light Flashing
Posted on May 22, 2010
Whisper quiet plus kitchen aid manual
Hello, As You Wish -
It looks like you can obtain the owner's manual for your Kitchen Aid dishwasher through the Kitchen Aid web site. It will probably be a download option for a PDF version of the manual. This is the link: https://www.kitchenaid.com/customer-service/manuals/ . You will need to enter the model number of the dishwasher.
Note: When I obtain a downloaded PDF user manual (for anything), I create a file in my Documents folder, giving the file the name of the product, so I can find it easily. Example: Kitchen Aid Diswasher. Unless the manual is hundreds of pages long, I also print it out and keep it in a paper file folder with other appliance and equipment user manuals.
Best wishes.
Dec 18, 2017 | Dishwashers
Kitchen aid dishwasher whisper quiet model door stuck closed
I found this on another site hope it works for you.Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
Read more: http://appliancejunk.com/forums/index.php?topic=5096.0#ixzz3Yhgf8Ihd
Feb 24, 2015 | KitchenAid Kitchen-Aid KUDD03DTSS...
My KitchenAid Superba (whisper quiet ultima) started to leak out the front when it is running. Is this an easy repair or should we think of replacing the dishwasher? BTW - we love this dishwasher!
Hello. If the unit is over ten years old, I advise against repair. But if you do wish to consider repair, here are the things to look at
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Mar 18, 2010 | KitchenAid Dishwashers
Kitchenaid Superba Whisper Quiet Ultima: It won't drain. I returned from a trip to find a puddle of water in the basin/reservoir, which usually drains during a normal wash/dry cycle. Now it'll shoot out...
Mar 13, 2010 | KitchenAid Dishwashers
Have a kitchen aid whisper quiet dishwasher...will not drain
Apr 17, 2009 | KitchenAid Dishwashers
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Water leaking from botom of Door
see if float cup is free on bottom of machine so it is not overfilling. take old toothbrush and clear any accumulated soap buildup from bottom of door and gaskets.
Feb 16, 2009 | KitchenAid Dishwashers
Jan 16, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
