Question about Niko SV-3706 37 in. LCD Television
Niko Sv3706 - When plugged in the Red idle power light is on but when turned on the light goes green then completely shuts off with no light nothing on screen when turned on
    Problem Solver:
Just fixed mine, when plugged in red light comes and goes, sometimes it ststays on but when I turn it on the green light comes on then off. Opened up tv, there is a heat shield of some sort,take off, there is a board where plug goes into the wall,it also has three more plugs plus a ground that is screwed to the tv.I looked at the board and there were two capacitors that were bulged and had brown stuff about to come out the top. They were 1500uf 16v 105c, I changed them only I made them 25v instead of 16. And boom life was good. Good luck and sorry for my spelling.
Posted on Nov 15, 2012
4 Suggested Answers
SOURCE: Niko Screen and channel problem
Fortunately, I have not had the fuzzy green screen problem in quite awile, and since getting the Dish, I have not had to worry about channel memory loss. I am thinking about turning this one into a computer monitor...is this even possible... and getting a bigger tv for the front room, HD of course.
Posted on Sep 25, 2008
jerryg50
  • 1667 Answers
SOURCE: will not turn on
I have not worked on your model of set. I can tell you generically my opinion from experience of servicing many TV sets.
Once a fuse or any failure to operate properly occures in solid state devices there is an actual fault. These systems have very well designed protection circuits and are computer controlled.
The pop you heard is most probably a direct failure of a component that is most likely feed from one of the main power rails on the circuit board where it operates. The first area of fault may be in the main power supply. In these sets there are several levels of power supplies. Because the pilot light on the set is not lit, I would assume that the main power supply has failed.
It is also possible that a power drive circuit has failed, and the main power supply is in the protection mode, or has also failed. Normally, if there is a failure and the power supply can still function enough to operate the uPC, the uPC will issue a warning. This results in flash codes from the pilot light.
If the fault is not complicated an experienced TV tech may be able to troubleshoot and fix the power supply at the component level.
Normally these sets are serviced by swapping out boards. The tech will try the suspect boards and leave in the boards that make the set work. The next step is to follow the service manual using the calibration instruments to confirm and adjust the factory level setups.
TV sets are not simple devices. There are many power drive circuits that operate various areas. Flat panel sets have some basic principles that follow that of the CRT sets, but for the most part they are very different and very complex in many areas.
I tried to find for you any direct authorized support contact information for your TV. I was not able to find any.
These sets can be fairly expensive to service. You could try a local service center. Ask for an estimate before servicing the set.
When buying a new set I would suggest for you to stay with a big brand name type set. Whatever set you choose find out if there is direct factory level service in your area for the set.
I hope this helps you out to understand more about the problem.
Jerry G.
Posted on Feb 04, 2009
  • 1779 Answers
SOURCE: where can I get a power cord for niko 26 inch?
95% of all LCD's use the standard PC or Monitor cord. Best Buy ect...
Posted on Feb 06, 2009
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
If my akai flatscreen 32in tv is moved or if the power goes out sometimes I plug it back in and the red light doesn't come on. Other times is when I'm watching it and I turn it off it goes from...
bad joint remove back panel with tv off check for any bad joints on power board also caused by thermal fault with tv on use a heat source over boards till tv shuts down then check suspect board
Dec 23, 2012 | Televison & Video
Niko sv3706 tv menu locked
Try this, press Vol- and Vol+ buttons at the same time to unlock osd menu and do the same to lock it.
Sep 16, 2012 | Niko SV-3706 37 in. LCD Television
Red and green lights work fine, but after green off completely, help?
Generally If System Is Unused For A Certain Amount Of Time Time It Will Go Into Was Is Called Sleep Mode. Also Make Sure You Locate Your Fan And Make Sure Its Able To Pull In Air For Ventilation Which Keeps The System Cooled Down And Wont Allow System To Get Hot
Mar 17, 2012 | Sony Playstation 3 (PS3) Console
My NIKO 1906W-R LCD monitor starts, but the picture goes off in about a second. The monitor shows the green light indicating it's receiving a signal. I'm looking for a service manual before opening it up....
There are two boards that need to be checked, the power supply board is one problem area "often bad capacitors that bulge at the top" the second problem area is the inverter board and often has bad capacitors, it powers the back lights.
Feb 01, 2011 | Niko 1906R (Black) LCD Monitor
Power problem
ok since it could be a number of things 1st always check that the cords are pluged in properly 2nd make shure that you spray the fan in the back with air in a can at least once a month
Jan 02, 2009 | Sony PlayStation 2 (PS2) Console
On my PS2 thin the red standby light is on and I push the button to turn it on, the light turns green like usual, but only for a second and then the light completely shuts off as if it was unpluged, after...
Try pulling the power adaptor out of the back of the ps2 ,then make sure no dust or debree is in the part that plugs into the ps2 then plug it back in and make sure its attached firmly. The ps2 should turn on now
Jul 12, 2008 | Video Game Consoles & Games
Doesn't boot up
try it pluged in without the battery, does it turn on?
when it shuts down, does the power light stay on? or is it just no display?
Jan 04, 2008 | Dell Latitude D600 Notebook
Niko SV-3706 37 in. LCD Television Logo
108 people viewed this question
Top Niko Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
