Computers & Internet Logo
Posted on May 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It seems that the network connections always responds "server not found" even if internet is connected...its frustrating....
Anonymous
Level 2:
  • Expert 38 Answers
  • Posted on May 24, 2011
Anonymous
Expert
Level 2:
Answers
38
Questions
0
Helped
11522
Points
101
Do you have a router in between your PC and internet connection (i.e. broadband, DSL, dial-up etc)? If so, I would bet you have a configuration problem inside the router. It probably has something to do with setting you internet gateway IP address, DNS addresses, or other IP settings (Static or DHCP). Hope this helps.
Testimonial: "yeah that seems to be it. I have also tried disconnecting the router and doing direct connections. I now trying to get hold of IP address etc...Thanks"
1helpful
Every night- at the same time- while watching Netflix on my Wii- through a WiFi connection- Netflix streaming will freeze, retrieve then fail. I can sometimes select Try Again and it will work for a short...
Hmm... I am not sure, but this can be because of your internet provider. Some IP's "reboot"their internet hosting servers to wipe all the non useful info that got collected over the day. I really dont know why you wouldn't be able to continue watching after the internet was back again.
2answers
Have RV042 set up with Cox Cable and ATT DSL. System works fine as long as all client computers on network have a Static IP. I have DHCP enabled on the Router, when connecting a PC set for DHCP the router...
> everything is good
The connection between each computer and the router is the "good" part.
Thus, the router is routing packets "between" each of the computers (clients & servers) within your local area network.
However, your problem seems to be on the 'WAN' (Wide Area Network) side, namely between the router's WAN port and the DSL-modem, and/or between the DSL-modem and the telephone-jack on the wall, and/or the telephone-wires inside your walls, and/or the telephone-wires from the outside of your building to the nearest telephone company's CO (Central Office).
As a test, disconnect the router from the DSL-modem, and directly connect one computer, to see if the "then it will/not" behaviour still happens when the router is not active, i.e., "bypassed".
Then, contact your ISP, and get them to trouble-shoot while that one computer is connected.
2helpful
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Network Error (tcp_error) A communication error occurred: "" The Web Server may be down, too busy, or experiencing other problems preventing it from responding to requests. You may wish...
This can be :
1-Your ISP has connection problems or connection speed is slow
2-The server you try to reach is busy at that time.
3-Or if you are under a network,the network itself is having connection issues.
If you need more help come back.Post / thumbs / testimonial are welcome!
Every time I run the DSL-504 ADSL2 Ethernet Router CD disc to setup my internet connection, always get the dslultility.exe message say "modam not deteched....." but everything is...
To release and renew IP address, go to Start > Run. Type in CMD and press Enter. At the prompt, type in ipconfig and press Enter. This will display the adapter information such as IP address, Subnet mask, and default gateway.
To view additional information such as Mac address, DNS servers, etc, type in ipconfig /all.
To release IP address, type ipconfig /release.
To renew IP address, type ipconfig /renew.
If you are not able to get an IP address try setting one statically:
Windows 2000
Step 1 Right-click on My Network Places and select Properties.
Step 2 Right-click on the Local Area Connection which represents your network card and select Properties.
Step 3 Highlight Internet Protocol (TCP/IP) and click Properties. Enter your IP information for your network.
If connecting to a router, make sure the default gateway and a DNS server is the IP address of the router (192.168.0.1).
Windows XP
Step 4 Click on Start > Control Panel > Network and Internet Connections > Network connections.
Step 5 See Step 2 for Windows 2000 and continue from there.
2answers
We installed AVG 8.0 on the server of our small office network on Saturday 31/05/08. However we now have "Big Problems" trying to access our S6 system on E:\ drive. (Solution6 accounting and...
Did you try uninstalling the AVG?Next you can also try a system restore but make sure you take a backup of all your important data.Bcuz once you do a system restore then you'll loose all your data as it will be restored to an earlier time.
Goodluck..
Grand Canyon Tech
Grand Canyon Tech
