Question about Whirlpool Dryers
Dryer is not drying igniter coming on but wont stay lit lites once in awhile
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 24, 2011
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
Dryer wont stay lit
if the flame is liting most likely problem is bad air movement.go outside with thedryer running and check the hood to see how strong the air is blowing out,if there's a cage or anything blocking the hood remove it,if the vent line is a long run remove the vent line from the back of the dryer,stick a leaf blower into it and blow out the lint to the outside.also with the dryer unplugged,remove the bottom panel,remove the lint filter and metal duct the filter slides into,clean that out and blow out the blower wheel with a shop vac,you can blow out the gas tube where the flame ignites to make sure it's clean blow off the motor and the cabinet and vac up all lint that blows forwards.you can try running the dryer with the vent line removed to see if it runs any better.when the dryer first heats up the flame will come on until the temp. is reached and it will shut down,one more thing to check,when gas coils start to fail you'll have heat for like the first 15 to 30 minutes,then when the coils heat up the ignitor will glow but no flame,after the coils cool down they will work again.how are you running it on timed dry or more or less dry,if you run it on auto or more or less dry there's a sensor inside where the lint filter is,try cleaning it up or try running it on timed dry to see if it runs any different,when on auto the heat comes on,when it reaches temp. the heat stops and the timer will advance,when it calls for heat the timer stops and the heat comes back on,it will do this until the clothes are dry.your model has an even heat board in it that can also cause problems but if the flame is liting it sounds like you have a block somewhere.go here this will tell you a little more about your model dryer.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
May 23, 2013 | Dryers
Dryer lites but wont stay lit
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 06, 2010 | Crosley CDG6000 Gas Dryer
We have a commercial inglis gas dryer..under door is a model number JO-71200 when i search for it says no match.dryer quit about a week ago we replaced a few rollers then we noticed clothes weren't...
Well I'm not familiar with gas delivery systems on dryers, but I can tell you how they work on home heating boilers and I'm sure they are very similar. There are two type, standing pilot (which you have) and spark ignition. Spark ignition uses two electrodes with an electric spark to ignite the gas. Now your situation your dryer may have what is called a thermocouple which is like a little metal cylinder connected to a wire. When the flame is lit it heats that thermocouple which produces a voltage. That voltage keeps your gas valve open to keep the pilot light lit. If your pilot light is lit then the thermocouple is not bad. You need to check your circuit and see where the break is. Its true it could be a thermostat. To check a thermostat you need to take it off the dryer and you can either use a lighter or put it in boiling water till you hear is pop or open up. If you hear it pop twice then it is good (you'll hear it pop once when it heats up and once when it cools down). There is a circuit that keeps that gas valve open, and after 10 seconds something is opening that gas valve circuit, you need to see what all is connected to it, then you will solve your problem.
May 08, 2010 | Dryers
My kenmore series 80 model # 110.74852400, takes forever to dry. the flame comes on, but doesn't seem to stay on for long. please help. thank you
my kenmore dryer ignites runs for awhile then wont reheat. let it sit for a few minutes and it will heat again for awhile
Apr 20, 2010 | Kenmore 72802 Gas Dryer
Roper Model RGS7648EQ3 (gas) that wont stay lit.
if the ignitor is liting for the first 15 to 30 minutes and then it will not lite again you have bad gas coils,when they are failing they will work until they get hot then they shut down,the coils are located on top of the gas valve,take out the two phillips screws,remove the cover,change out one coil at a time,pull off the wire connector and install the new coils
Mar 19, 2010 | Dryers
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
Alantis Gas Dryer MDG7600AWW not staying hot or lit
All you need to do is replace those pesky intermittant coils
aab79a0.jpgI wote a short essay on this problem. To keep from being redundant I have it HERE
Mar 02, 2009 | Maytag Dryers
Gas Dryer won't stay hot
There is a thermoelectric eye that says it is OK to keep the gas burner on. If this sensor is defective or blocked from "seeing" the gas flame is properly lit, it will turn off the gas flow (safety) override solenoid. With the unit unplugged make sure that the optical path on the upper right (1:30 CW position) flame tube inside sensor window is clean. The rattle you hear is probably the safety gas shut-off solenoid engaging. If you need more help, please ask -- SWT
May 03, 2008 | Dryers
Kenmore gas dryer igniting problem
check the flame sensor. it could be the problem since it would ignite first then if the flame sensor is mal functioning, it would indicate a "no flame" signal that would cut off the fuel solenoid. then it would shut it off.
Feb 13, 2008 | Kenmore 63942 Dryer
Dryers Logo
55 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
