Question about Speed Queen AGS28AWF Gas Dryer
I have a speedqueen gas dryer model AGM499w iGNITER LIGHTS BUT NO FLAME
  • Speed Queen Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Posted on May 24, 2011
Speedqueen flame stays on for only 30 seconds then goes out, puffs back towards gas valve
when was the last time you cleaned out the dryer and vent line,if the air can't move to the outside vent the gas will shut down,remove the vent line from the back of dryer to see if it runs longer,also clean out the duct where the lint filter slides into,it sounds like you have lint blockage either in the dryer or in the vent line.
Jan 15, 2014 | Speed Queen AGS17AWF Gas Dryer
Magic Chef wall oven model no. 9122xpb
Ignition control problem or flame sensor problem...........
Either the flame sensor is not sending a signal to the ignition controller or the controller is faulty
Aug 29, 2013 | Dryers
Gas Dryer Ignition Issues
did you try bypassing the cycling t-stat also?
Aug 25, 2012 | Samsung Dryers
Speedqueen gas dryer switch mechanism
my guess would be the door switch is not working somehow as it should start if the lights are on
Feb 01, 2012 | Dryers
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
I have a roper gas dryer model rdg4440sq0, the igniter glows then the flame lights. Then the flame goes out and doesn't light up again. When it cools down and i restart the dryer the igniter glows and...
If when the flame goes out ...Check to see that the igniter glows...If it glows and the gas does not light then replace the valve coils...Very common problem.....The coils are to weak to hold the valve open..
Apr 20, 2010 | Dryers
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
The gas dryer ignites with small flame but does not fully ignite when set to high cotton setting
you need a dryer conversion, it sounds like it is set up for lp gas
May 17, 2009 | Dryers
I have a Speed Queen gas dryer AGM499W. It won't dry. The gas ignighter comes on but gas does not light.
There is a light sensor near the igniter. Clean off the dust on it's glass face. Don't bump the igniter, it's delicate.
Apr 22, 2009 | Dryers
Speed Queen AGS28AWF Gas Dryer Logo
222 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
