Question about Astatic 878HL2 Microphone
I need wiring for ranger RCI-2950 - Astatic 878HL2 Microphone
Where can I get a cpu board for my ranger 2950?
get hold of ranger and they should be able to help you.
Mar 18, 2013 | Radio Communications
Ranger rci 2950 will not transmit
have you tried it on all bands? still won't transmit?take it to a tech so they can fix it properly.
Sep 16, 2012 | Ranger Communications RCI-6900F-25 CB...
I have a RCI 2950 comes on keyed up and stays keyed untill you turn it off. I have replaced the auto amp, all voltage regulators and the black diode with yellow strip below mic plug with no change. I need...
i have the same radio rci 2950. Ive had the same problem with mine,turns out with mine the processor would lock up,turning the radio off & on repeadly would clear the problem and the radio would work fine x-mit & recieve. the solution to fixing the problem is to replace the memory backup battery this battery works similar to a computer motherboard cmos battery when this battery goes dead all sorts of strange things happen to the radio wont transmit wont recieve or like your problem transmits continiously. the problem with replacing this battery is finding out what year & model your ranger 2950 is. the internet says only first generation ranger 2950s use the battery second genration & third generation do not use the battery. but the internet could be wrong. so i suggest getting a hold of (usa ranger.com) & give them a phone call or email and ask them about the year your radio was made. they may even service it for you or if you are electronic savvy you can do it yourself. the battery is located close to the main cpu on the front panel if yours uses a battery.
Sep 07, 2011 | Ranger Communications RCI-6900F-25 CB...
Lack of receive on a ranger 2950
Bad mic? dirty mic pins? If the mic is bad, you will have no receive.
Nov 10, 2009 | Ranger RCI-6900F-25 CB Radio
I need a manual to base station CB Ranger rci-2990. Can you tell me where to download or purchase this manual. Thanks
http://www.rangerusa.com/websupport.html
http://www.worldwidedx.com/cb-band-cb-radios/18036-manual-rci-2990-a.html
you may find some help with these sites
Sep 24, 2009 | Radio Communications
Ranger rci-2950
Hopefully it's as easy as this carefully take the cover with the speaker in it off and look to make sure the speaker wire with the plug is plugged into the two prongs sticking up in the back right side corner it is a very tight fit though.Good luck Dan
Aug 28, 2009 | Ranger Communications RCI-6900F-25 CB...
No channel readout in front of radio ranger 2950
replace memory battery its a CR2032 battery Radio Shack and Walmart has them from $3.65 to $5 in price.
Jan 11, 2009 | Ranger Communications RCI-6900F-25 CB...
RCI 2950
Hello, Just offhand I'd say you have a bad solder joint on the main circuit board. Without more info, I can not tell you where to look,,,,, Mechanic
Jul 09, 2008 | Ranger Communications RCI-6900F-25 CB...
Astatic 878HL2 Microphone Logo
54 people viewed this question
Top Astatic Audio Players & Recorders Experts
Michial Gueffroy
 steve
steve
Michael P
Level 1 Expert
Are you an Astatic Audio Player and Recorder Expert? Answer questions, earn points and help others
