I tried to boot my emachine250 netebook with the external driver but there is no driver found to follow the installation. what can i do?
    Problem Solver:
  • 11 Answers
At the time of boot press F8 and select the the drive from u what to take bootit may be possible that u may not see the boot display for few seconds but you must F8many times as soon as u switch it on till the boor option comes
Posted on May 24, 2011
Burned boot to external hard drive, now external is local. Can I get it back to local? does I
when a hard drive dies , everything is lost and I mean everything
no recovery disc , files , folders e-mails , operating system --the lot
best move is to install a new sshd unit and change the bios to boot from the external hard drive
when that is done , you will have to down load all of the drivers for everything you use
Sep 10, 2017 | Compaq Evo N620c Notebook
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
Hello! Here is my problem; I have Gateway MX6426 laptop and CD drive went off. When I try to install Windows XP from external CD drive some problems occurred. I put CD in ext.CD drive,run clean...
Press F1, ie for Gateway to enter Bios settings.
Go to your BIOS MENU,
From "Boot options" set 1st boot to "removable drives" save the setting, ie if you are using an external CD/DVD or USB flash drive. If you are using an external CD/DVD Rom, ensure that the power supply to the external CD/DVD Rom drive is sufficient.
Try and reinstall the Operating System again.
Hope it helps, and good luck.
Oct 11, 2010 | Computers & Internet
After it boots up and goes to the desktop the screen cuts off. the power button is still lit up but the screen is blank.
During boot up press function key F8 repeatedly until the windows boot menu appears. Select boot in safe mode. If this works make sure the correct video card is selected for the laptop. Go to your control panel click on system then select the hardware tab and click on the device manager. Select display adaptor and click on the plus symbol to expand the selection. Double click on the display adaptor and select the driver tab. Click roll back driver or uninstall the driver. Reboot your system normally. When windows prompts you to install the newly found device follow the instructions to install the graphics card driver.
If this does not work connect the laptop to an external monitor to see if you can see the video on the external monitor to find out if the graphics card is working.
Aug 13, 2010 | HP Compaq nc6000 Notebook
I want to reinstall Windows XP Professional my own.
If you want to do so...you can follow these procedure:
  1. If you don't have the CD/DVD, Buy your genuine MS Windows XP Professional SP3 and Windows Office 2007 (I can't suggest you the price, it may be vary).
  2. Write down all Computer Device type (you will need it when installing device driver). To find it, right click on your "my computer" icon on your desktop and click "manage". Locate "Device Manager" and write down all device that listed here. But do not to worry about it, most of well known device are included in Windows Driver out of the box. For some computer, the driver could be found on the CD that shipped with the computer when you've purchased it.
  3. Copy all of your data (i.e in "My Documents") into your external Hard Disk or other backup device such as DVD or CD.
  4. Make sure your computer's boot priority set to "boot from cd" as first priority. You can set it in BIOS option.
  5. boot your computer, and follow instruction from Windows CD (it will be easy thought, it almost clear for every instruction).
  6. After the installation finished, you might be needed to install device driver.
  7. Install Office 2007 and follow the instruction (believe me, it's easy!)
  8. Copy back all of your data from your external harddisk to your new "My Document"
  9. It's all done
But, you might be found some problem during the installation, and it may be vary...just ask me again with your new problem then...I will try to help :)
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 12, 2009 | Microsoft Windows XP Home Edition
Cannot reload operating system
for xp in acer 5315 you have to load sata driver from external floppy disk with floppy and press F6 optin at starting point of xp boot disk while booting.
and follow the instraction when ask for sata driver spacification.
and enjoy loading xp.
Jan 19, 2009 | Acer Aspire 5315 Notebook
Install screen and drive won't boot up anymore
Hi Doug,
The problem is that mac has a diffrent 0perating system to a pc the thing you doing by switching from mac to pc the external hard drive is conflicting with one another to make your external driver to work on your pc follow these steps. go into control panal,system,hardware,device manager,universal serial bus controllers,drivers then update drivers that should reconise your mass storage driver.
Jan 16, 2008 | Computers & Internet
Install xp pro
windows xp cannot be installed on a system with pre loaded vista . because the boot loader of xp is older than vista as it cannot create boot loader . the order of installing operating systems is from LOWER 2 HIGHER ie XP to VISTA . first of all u nedd to format drive containing vista and then try installing xp
Dec 14, 2007 | Creative Labs Sound Blaster Live! 24-bit...
Computers & Internet Logo
David Payne
David Payne
