Question about Garmin Nuvi 1450LMT
I just received my neww 1450LM Garmin Nuvi GPS today and it push the on/off power switch and it does not come on. so, I started my car and plugged it in and it still does not come on. Please tell me why it does not power up when plugged into the car. Tried several of my vehicle and it does not power up. Do I need to charge it before it power up even if you are using it plugged into your car. I had another Garmin Nuvi GPS and when I got it new it powered up right away. I get ablsotutely nothing with my new 1450LM Garmin Nuvi GPS. Please help!!!!!
  • 1,116 Answers
Garmin is voluntarily recalling certain nuvi devices that contain a specific battery that was manufactured by a third-party supplier within a limited date code range.
Garmin has identified potential overheating issues with the use of these batteries in certain nuvi devices with a specific printed circuit board (PCB) design. Additional information about the nuvi battery PCB recall can be found in Service Alert Number: 1035.
The models that may be impacted by the nuvi battery PCB recall are the 200W, 250W, 260W, 7xx and 7xxT (where xx is a two-digit number). To determine if your unit is affected, please visit www.garmin.com/nuvibatterypcbrecall and enter your nuvi's serial number. If your unit has the specific PCB design and contains a battery from the specific date range, you will be given instructions on how to return your nuvi for a battery replacement at no charge.
You should not attempt to remove or service the battery on your own; all battery replacements must be serviced through Garmin's authorized service provider.
If you do not have web access, you may contact Garmin through one of the phone numbers below:
  • In the United States and Canada, call (866) 957-1981
  • In North America and South America outside the U.S. or Canada call (913) 397-8200
  • In Europe, Middle East, and Africa, call +44 870 850 1242 or 0808 238 0000
  • In Asia, call 886/2.2642.9199
  • In Australia, call 1800 113 738; and in New Zealand call 0800 427 652
Repair time will vary based upon location. U.S. customers, please allow 10-16 business days to receive your repaired or replacement device. Canadian customers, due to increased shipping and customs clearance times, please allow 20-30 business days to receive your repaired or replacement device.
Garmin sincerely regrets the inconvenience that this recall has caused and is making every effort to cooperate with customers, dealers, and regulatory agencies worldwide to ensure all parties are assisted according to national regulatory standards
Posted on May 24, 2011
Tip
How to Perform a WebUpdate of the Garmin Nuvi 205 and 205W System Software
Does your Garmin Nuvi 205 or 205W get stuck or freeze at startup or when loading maps?
One trick to try when your GPS is acting up is to perform a Hard Reset.
Occasionally, your GPS may not start properly at all, and display a 'System Software Missing" message. Today's tip will describe how to restore your Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your PC and update the system software of your GPS.
Your Garmin Nuvi should be running as good as new.
on Jan 17, 2010 | Garmin nuvi 205 GPS Receiver
When I turn on the unit the word Garmin keeps flashing over and over, won't start up.
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck...
Nov 13, 2011 | Garmin nuvi 1350 Car GPS Receiver
Garmin Nuvi 760 gps Unable to calculate route No roads near starting point
I have same issue Garmin Nuvi 760 gps Unable to calculate route No roads near starting point started this morning. Has worked fine for 2 years till today. David W
Aug 02, 2010 | Garmin Nuvi 660 GPS Receiver
Will not load map. I plug it in an it starts and will not shutdown. Just says loading maps
Take care.
Jul 20, 2010 | Garmin nuvi 255W GPS Receiver
My Garmin nuvi 250W GPS is NOT powering on.
try connecting it to your computer via the usb cable. that may reset it. outdated maps will not cause this problem.
Feb 21, 2010 | Garmin nuvi 250W GPS Receiver
Garmin is stuck on Warning screen --
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Jan 03, 2010 | Garmin nuvi 205W GPS Receiver
My garmin nuvi 1300 won't turn on. It should be fully charged as I drove a couple hours with it plugged into my cigarette lighter. Nothing happens when I push the power button. I've had it for not even a...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Dec 28, 2009 | Garmin nuvi 1300 Car GPS Receiver
Garmin Nuvi will not switch on
If you are using the cigarette light adapter plug-in, you probaly blown a fuse in the plug.
Unscrew the silver / or black tip of plug.... carefully its spring loaded.... check fuse
Mar 26, 2009 | Garmin NUVI 710 Car GPS Receiver
Garmin Nuvi 1450LMT Logo
432 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
