Question about Bosch Dishwashers
My trusty Bosch s510 Dishwasher which has been going strong for about 17 years (at least) has just decided not to empty itself. I noticed the bottom was full of water after a wash. I emptied all the water out by hand and presuming there is a blockage in the drain tried using a plunger to unblock it. I have since put it through another cycle and half way through water started leaking out of the front. At the end of the cycle the bottom of the dishwasher was again full of hot 'soapy' water. If there was a blockage somewhere in the in the outlet pipe/drainage system and i cleared it with the plunger would water then just drain away or is there a valve which opens only at the appropriate part of the washing cycle and therefore the only way to know if its cleared is to run the machine? Any suggestions as to what i should try next?
  • NancyJL Dec 26, 2008
    SHU3035 stopped draining every time - drained every 2nd cycle - then stopped completely.
    If I empty by hand and run again, it refills but again doesn't empy. It's a pretty annoying way to do a load of dishes - once with soap, once without.
    Pump? Pump belt? it's not a blocked drain, we checked it out thoroughly (without using a plunger).
Same problem, so went out and bought a new bosch. Problem with the S510 was cured by lubricating the pump out motor bearings with a squirt of WD 40. If you don't know which pump, follow outlet hose to pump outlet.
Les
Posted on Jan 18, 2010
  • Robert Apr 18, 2011
    Been over a year but for future inquiries I had the same problem...the repairman found that the filter -grill was plugged by seeds or pits ! Once they were "dug out", the screen was cleared and the water emptied completely.
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
May 14, 2012 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Bosch Dishwasher will not dry dishes, washing is fine. Model SHU43C05UC / 17. About 4 years old. Cannot find the manual. Any help is appreciated.
Bosch dishwashers do not have built in heated dryers. Be sure your water is hot enough and the rinse aid dispenser is not empty. The Bosch should heat your water to a minimum temp and if it is not, this could be your problem.
Ken
Oct 25, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Large blue band appeared on lower tray following wash cycle,
So. We had the same problem tonight and I have been sitting lookin at this thing for an hour and decided to run it and see what happened with no rubber band in there. After the cycle was over I noticed that my wife washes those "snap wear" containers in the dishwasher and these items have colored coated Mylar bands as sealers. When they heat they expand and can be dislodged. It was a coincidence that it wrapped itself around the bottom spinner. Myth debunked!!!!!
Mar 10, 2010 | Bosch Dishwashers
Bosch SHU 4000 series dishwasher; Water keeps on filling
The inlet valve will be at the dishwasher end of the (hot) water inlet line. On this dishwasher I ~believe~ the inlet valve is near the rear of the unit. That means that you will need to pull the dishwasher out to get to it. Remove power from the dishwasher as soon as you can before messing with the unit.
Just past the connection of the supply hose and the connection on the dishwasher, there will be the valve (a solenoid valve with two wires coming out of it.) That is the little beast that has most likely failed.
Good Luck!
Jan 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher approx 14 years old
modek no is usually on a label on side of door or etched in on side or top of door.
black staining not due to heater but possibly from rubber door seals
Nov 20, 2008 | Bosch Dishwashers
Bosch Dishwasher leaking
I had the same problem it turned out that the upper rack was not being pushed back all the way so the door was slightly ajar. If you open the door you should see a bit of water going past the seal If the door is not seating.
Henry in Toronto
Jun 30, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher
what is the model #?... there are 2 buttons when pushed together it will drain the water out..try the button to the left next to power scrub... and economy...hold the 2 buttons for 3 sec. you will hear you drain pump running.. if you don't hear any water draining out into your sink, you might have a clog d/w drain line.
May 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher water comes in and goes stright out of drain
is the drain upto specifaction? sounds like its siphoning. should be in your manual
Sep 22, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
1,314 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
