Question about Cell Phones
I have to push up the charger for so long to charge and i need to call someone
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 104 Answers
Charging port needs to be resolded depending on what phone it is
Posted on May 24, 2011
Have to push power adapter hard for tablet to charge
The power port is damaged - most likely the solder joints are loose or broken. You need to find a store where someone can open the case, order the new part for the tablet and then solder the new power port to the board.
Then it will be as good as new.
I have replaced power ports on laptops, phones and tablets.
May 24, 2015 | Tablets & eReaders
Hi I have a ezip 400 scooter we just bought a new charger and the charger has a green light but the ezip its charged I was thing maybe its a loss wire or something I got the ezip from someone said if
Push the circuit breaker back in first. The scooter will not move if the charger is connected. If the scooter has sat unused for a long time, the charger will NOT recover the batteries. Charge them individually with an automotive charger until the voltage is at least 11 volts each. May take a 12 or more hours. If you can't get 11 volts after that time then the batteries are gone.
Oct 04, 2014 | Health & Beauty
My car's 12 volt battery died 1 week ago. i bought and attached the Schumacher XC6-CA battery charger. The battery's fluids are good and i bought the battery in mid 2012. How long should it take for
if the battery is flat and below 5 volts the charger on digital charger dont charge, you need an old charger one with a 4 to 6 amp charging capacity to charge the battery, digital chargers have a safety device on them to stop the charger from working as when a battery becomes faulty it stops charging.
Aug 02, 2017 | Electrical Supplies
Samsung r519 charging port problem
Try someone elses charger in your pc, if same fault, its your pc
Jul 09, 2012 | Samsung R519-53S Notebook
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
Acer laptop won't charge.
When you finally get the charge light to come on, does the battery get fully charged? How long can it run while not plugged in?
A junker will not charge properly, or hold a charge for a short period of time. If this is the case, time to get a new battery.
If the battery seems to charge fine and the uptime is acceptable take a look at the charger and connectors, make sure their clean and free of debris. Maybe try to locate someone with the same charger and see if the problem continues (Some computer shops may have your charger)
Jul 17, 2009 | Acer Computers & Internet
The battery to my fujifilm z10 camera wont charge when i stick it in the charger
I had the same problem. I had to buy a new charger...You could borrow someone else's battery and test yours..then you would know whether your problem is the battery or the charger. Also, just a thought The outlet you are plugging the charger into-is it a GFI plugin with a little red button on it? if so is the little red button pushed in?
Aug 06, 2008 | Cameras
Motorola L6 charger is getting hot
ITS HOT ? OR WARM ??
IF WARM ITS NORMAL
IF HOT ITS HOTTER CHECK IT 4 PROPER VOLTAGE
IF PROBLEM STILL REPLACE IT
DON'T FORGET RATING IF USEFUL
Mar 10, 2008 | Motorola Mobility L6 Cellular Phone
Samsung Digimax U-CA 5 : won't turn on....
You might want to try a new battery for it.
Before you do that, plug the camera into the charger and see if if opens. If that works, you need a new battery. It isn't charging anymore.
Dec 06, 2007 | Samsung Digimax U-CA 5 Digital Camera
The following
Hi how old is the charger often the wires inside the charge fray and short either try somebody elses charger or try you charger on someone elses phone if the charger is working ok then it could either be that the battery needs replacing or that the board is warped on the phone first of all i would try someone elses charger this way you kno the charger is working or not let me know how you get on ok
Dec 01, 2007 | Nokia N73 Cellular Phone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
