Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
I purchase a Malibu ML600TW. My quest is. In this unit are there 2 separate 300 watt transformer. or when you contact the line in you are wiring to 600 watts.
With the 600 watt ML series, there are two sets of a-b-c terminals. C terminals are used with photo eye.
Connect 300 watts of bulbs to one set a-b terminals, connect 300 watts to other set of a-b terminals.
I'm not sure what is inside the power pack. However if you run less than or more than 600 watts or let your bulbs burn out for any length of time, the power pack can burn out. Save your receipt for limited 5-year warranty.
For your benefit, open following link for more information on ML power packs, plus troubleshoot, plus tips to keep power pack from burning out, and links to trippers:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 24, 2011
I have a ML500TW timer transformer I don't believe they make it any mor can I replace it with a 600
Yes, use ML 600 with 5 year warranty.
Save receipt.
Copy following link for useful information about getting new power pack to last longer.
ML 600 will have 2 sets of ABC terminals.
Each terminal supports 300 watts.
Split lights between both sets of terminals.
Use 12 gauge wire. Maximum 75' length each wire.
Apr 15, 2013 | Malibu ML600TW - Low Voltage Power Pack -...
Malibu transformer with plastic fittings how to connect
1) Copy following link for full resources on operation, wire length, bulb wattage, warranty, troubleshoot, etc
2) Add comment Dec 2012 for more qassistance
Dec 15, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
How to install Intermatic ML600TW
Copy following link for ML600 installation manual, installation tips, problem-avoidance, troubleshooting, replacement trippers, warranty information:
With the ML600, there are usually two sets ABC terminals.
Connect wires to AB terminals unless using photo eye.
Connect 300 watts to each set of AB terminals.
Nov 22, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
Loud huming from my 300v low voltage lighting transformer
Transformers make humming sound.
ML300 series transformers make sound.
Used styrafoam to separate transformer from contact with building so sound is not carried.
These transformers have 10 year limited warranty.
Copy following link for general troubleshoot and tips, and warranty information, and trippers.
Oct 23, 2012 | Malibu ML300RTW - Low Voltage Power Pack...
Have 5 year old ML600TW carrying 320 watts on one side. Stopped working. Noticed it has a circuit breaker internal. Is it possible to open unit and rest circuit breaker. Thanks
I've never heard anyone fixing a power pack transformer once it stopped working.
You could be the first.
Add a comment and say what you discover.
Open following link for troubleshooting resources:
Instruction manuals say to match bulb wattage with power pack wattage.
Aug 18, 2011 | Intermatic & Malibu& 300 Watt Power/Pack...
Two things, what size and thread screws on the wire connections and are there separate on off cycles for each 300 watt unit if so how do you set them separately \
ML series power pack has 2 sets of A-B-C terminals.
1) The terminals are not on separate circuits.
2) Typically, Intermatic timers have 10-32 screw.
Open following link for Intermatic/Malibu resources, tips and links to Malibu and Intermatic manuals.
Add a comment for more help.
Upvote the help.
Jun 12, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
I need to get the manual for the ml600tw low voltage transformer
Malibu website
Malibu manuals
Select your power pack guide
On the manuals page, I see 600 Watt power pack Model 8100-9600-10
May not be exact manual, I bet it is close
Oct 08, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
I have a ML300RTW and the off / on switch became stuck. After taking the unit apart I discovered the plastic switch melted and can not be reused. Can I get a replacement part for this because this works in...
I do not think that you can purchase a switch, if so the only one that would sell it would be Malibu. I would try on line to them direct as one last try before having to purchase a new timer. The amount of lamps that you have on this clock is not to many, you just need to add the total wattage of all lamps on transformer and as long as you do not exceed the rating (in your case 300 watts) you will be fine.
Sep 26, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
I just purchased some spotlights to add to my already installed malibu landscaping lights. I upgraded my transformer to 300 watts since the total wattage used comes out to 220. The lights on the end of...
Yes, using a larger wire will help, as will using more than one run. If you want too, you can leave the 16 gauge wire in place, then run the new 12 gauge wire and transfer most of the lights to the new run.
The fewer lights on a run, the less dimming will occur, so put more lights on the 12 gauge run.
Also, the longer the run, the more dimming will occur.
You may want to reconsider the location of the transformer, if possible. In your case, it would be better to locate the transformer in the middle of the current run, and just split the run in half to make a run in each direction. Of course, that depends if you have a 120 volt outlet available in that area.
Jan 03, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Lost manual i need to hook up the wires to the transformer
Open following link for Power Pack trippers, troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
Aug 30, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
229 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
