Sound stop working all of a sudden. problem happens often. dont know if it has to do with settings. i have an onkyo tx-nr807. please help
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 24, 2011
My TX-SR702 receiver often displays a 'Dialog
Need to know your source and exactly how that source is connected to the receiver. Also need to know what surround sound mode you are using and whether the program material that drops out is compatible with that decoding format. Might be as simple as changing surround modes when this happens, but you should know that many cable boxes and some disc players routinely drop their digital audio signals from time to time and can give you these symptoms. Best remedy is to call Onkyo tech support with all of your information requested above documented in one place. They can help you troubleshoot while you are in front of your receiver.
For Product Support Team Only:
1-800-229-1687
Hours:
M-F 9am-8pm | Sat-Sun 10am-4pm ET
Jul 24, 2010 | Onkyo TX-SR702 Receiver
Onkyo tx-nr807 no sound from speakers no matter what i do the sound just stopped. I changed no setting no wires and the sound had worked for 2 months. firmware updated weeks ago. The sound stopped working...
The reset will wipe out all of your settings. If you remove the power momentarily you will probably clear the problem and not have to go through the setup procedures again. This has worked for me on a number of problems with this product.
Jan 18, 2010 | Audio Players & Recorders
Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Apr 09, 2009 | Onkyo TX-SR701 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-DS797 - No sound
There is a technical bulletin from onkyo where in the problem is in the relay ckt
Sep 02, 2008 | Onkyo TX-DS797 Receiver
Onkyo tx-sr804 ..problem with the remote
PRESS THE RECIVER BUTTON THIS SHOULD WORK THE AMP AGAIN.
HOPE THIS HELPS.
CABLE GUY.
Mar 26, 2008 | Onkyo TX-SR803 Receiver
Default volume too high
You can download the manual from the link below: http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds787_manual_e.pdf c. Power On Volume This sets a designated volume setting for the TX-DS787 to be set every time that the power is turned on. This prevents the TXDS787 from being turned on while it is set to an extremely high volume and suddenly output very loud sounds. For the absolute volume display method, this can be set between min and max. For the relative volume display method, this can be set between ?? and 18 decibels. If you do not mind having the TX-DS787 turned on with its current volume setting, set this to "Last." Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 03, 2007 | Onkyo TX-DS787 Receiver
90 people viewed this question
 Grubhead
Grubhead
