Question about Bryant Heating & Cooling
We have a Bryant 556a model, puron Central air saystem. The air handler unit keeps blowing the 5a fuses. I replaced the filter. I cleaned the main contactor at the compressor. It ran for a couple hours and is now back blowing 5 amp fuses. Help!!
    Novelist:
    Scholar:
  • 187 Answers
It sounds like that contactor is the culprit. My reasoning is that after you fooled with it, it worked for a while before resuming the problem A new contactor costs about 15 to 20 bucks and it would be no chore to just hook up the two thermostat wires to the coil from the old contactor. You only need the power from the inside thermostat wiring for this test. Make sure you have pulled the high voltage fuse block power. Simply put the system in the call for cool mode and let the contactor pull in and see if it stays in without blowing the fuse. If after more that 2 hours passes with no problem you know it is the contactor. The only thing left would be to change out the low voltage wiring between the condensing unit and the air handler and next the circuit board. That board will and has failed for my customers but its not too expensive, you might want to shop it. Good luck.
Posted on Jul 04, 2014
  • 413 Answers
The small wires that go from your furnace to the outside unit could be freyed or bare and touching something or maybe even together. Some time dogs will chew these wires outside or under a house if you have a crawl space. You may need to inspect the wires . If looks bad, you can go to a local hardware store and buy new wiring.
I have seen the contactor also blow this fuse. Especially if the contacted are pitted or at time the 24volt coil will be shorted.
These are the two main problems that could be occurring. Good luck. Mark
Posted on May 24, 2011
Control board grounds out
Does the 5 amp fuse on the board keep blowing?
Dec 02, 2012 | Carrier Bryant Control Board Air Handler...
I have a Bryant Heat pump installed 10 years ago. It keeps blowing a breaker(now a fuse) in the air handler. I have had a technician out here three times. He has replaced all four relays and checked for...
One of the heating elements is stretching enough when it gets really hot and it is touching a metal part somewhere which blows the fuse...
Pull the heating element part out and you should be able to see where it is arcing and causing the short...
heatman101
Feb 14, 2011 | Heating & Cooling
5 amp fuse in central Airconditioning unit keeps blowing, I keep replacing, somtime is good for long time and sometime for really less than a day
You have an intermitent short in your low voltage wires. You need to trace the wire all the way to the A/H and then to the condensing unit. I bet you will find a bare spot. Check where the wire goes through the brick to the condensing unit. Ground squirrels are bad about chewing though the insulation. if this is where the short is, replace the wire from the A/H to condensing unit.
Nov 14, 2009 | Bryant 462AJC021BA Air Conditioner
Bryant Legacy Air Conditioner doesn't blow out cold air
Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
May 27, 2009 | Bryant 462AJC021BA Air Conditioner
AC will not cool. How much should a service charge cost?
If the upstairs is working and the down stairs is not,You only need to have one unit checked,Don't assume it just needs puron(If it does,You have a leak,which cost more to locate and repair than some other likely causes)This is not something you can do yourself and is illegal if you are not EPA certified.to get a fair price would depend on your geographic location and the best way would be to call around to some local heating and air companies and ask how much a service call is.(That only tells you the price for them to came and see what the problem is,They will not be able to quote a price until they know what must be done to make the repairs.
I hope this has answered all your questions.
Please take time to rate this fixya
May 16, 2009 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
171 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
