Question about Sony STR-DE595 5-Channel Amplifier
Sony STR-DE595 Sound not balanced
The right front channel is barely audible. I have to turn the balance all the way to the right to get any significant sound out of the right front speaker. Even then, the left channel is still much louder. (btw - the speaker is NOT the problem. All connections are secure and I have checked with other speakers, as well as headphones and still have the same issue). This happens whether it is in Stereo mode or if there is a digital signal (DD, DTS). I also tried changing the speakers from connection A to B, but the problem persists. I have done both of the resets mentioned in the manual, with no change.
  • soonerjohn Mar 27, 2009
    I got a new, better model on craigslist for half the cost of service on the old one and put the old one out on the curb
    Genius:
  • 1,175 Answers
HI...
It will need tech service.
Check the Sony consumer site for who can do it.
Posted on Mar 27, 2009
  • Scott Frye
    Scott Frye Mar 27, 2009
    Probably a good idea :)
    New Friend:
Did you ever figure this out? This is the EXACT same issue I'm having with this receiver.
Posted on Oct 07, 2015
No left a or b speakers
have you checked the speaker balance position as what you describe indicates you have the setting all the way to the right
Oct 03, 2016 | Audio Players & Recorders
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
NO! It uses the same amps for a and b channels. and you could short it out if its wirer improperly.
Dec 17, 2009 | Sony STR-DE595 Receiver
The sound on my sony amplifier sounds too low inside the speaker.
Try getting the suround sound modes off and using straight stereo ,with no delays,or echos,
Jan 12, 2009 | Sony STR-DE595 5-Channel Amplifier
Playing ipod on sony str-de595 receiver
You need a 3.5mm mini jack coupler lead with phono plugs on end plug one end into your headphone output on ipod and phonos into your amp lead must be stereo
Dec 22, 2008 | Sony STR-DE595 5-Channel Amplifier
preamplifier or power amp internally but check your signal cables for shorts or breaks,if amp then is internal and needs to be serviced
Aug 13, 2008 | Sony STR-DE595 5-Channel Amplifier
SONY STR-DE305 FUSES
are these the speaker output fuses...if yes, they should be on back panel. if no, then are you also looking for board mounted fuses on the pc board?
Jun 01, 2007 | Sony STR-DE595 5-Channel Amplifier
Sony amplifier/vcr problem
The Dog must have not liked the program? No what you need to do first is check the things that you overlooked as obvious? Such as mute switch, Balance control, Not in the right mode, speakers turned off, Audio cables pulled out of the unit. In tape monitor mode. Thats the most common thing if you have no sound after a bump from the rump of a dog,person playfull partner. Good Luck
Jun 17, 2006 | Sony STR-DE595 5-Channel Amplifier
Sony STR-DE595 5-Channel Amplifier Logo
500 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
