Question about Kenmore 54501 Dehumidifier
Fan runs, compressor switch seems to click but fails to start. Compressor is warn to the touch.
  • Kenmore Master
  • 43,501 Answers
The compressor is not starting, either the start components (relay and capacitor) have failed or the compressor is no good.
Here is a tip that I wrote to help people tofigure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 24, 2011
I have H. Bay model HB40F dehumidifier. It does not seem to ever actually start the compressor. There is a plastic box on the side of the compressor that contains a couple of coily looking things. It...
It is probably the start device(the coil looking things), as long as you don't hear the compressor humming. A loud hum is a lock compressor and the cost would be far greater than a new unit.
Jun 17, 2011 | Soleus Dehumidifiers
Fan runs ,coils are room temp. should they be hot or cold , no water is collecting in bottom
A dehumidifier is basically an air conditioner, so some coils should feel hot, the others should feel cold.
If no water is collecting, then the unit's compressor is not starting. Typically you have four possible failures causing this: the switch/wiring for the compressor has an open circuit, the motor-start capacitor for the compressor has failed, the compressor itself has failed, or all the refrigerant has leaked out.
If there is evidence that it is 'trying to start', but then clicking repeatedly, this can be a symptom that the refrigerant has leaked out, as some devices have a pressure switch to prevent compressor damage.
Also, a failed start-capacitor can also cause the click-click noise if the device has a current limiter switch on the compressor.
So the short answer is, it's broken :)
Oct 21, 2009 | Whirlpool AD25BBK Dehumidifier
Seem like the compressor is not working very hot
Assuming this is the A/C compressor, right? The compressor will be hot to the touch, the question is whether or not it is engagining when turned on, Check to see if the compressor clutch iis working by having someone turn it on and off while listebibg an observing the compressor clutch. Low refrigerant would or should orevent compressor operation to protect the compressorthrough a safety switch. Good luck
Aug 21, 2009 | Dehumidifiers
Everything seems to run fine, just hasn't pulled a drop of water
remove the back airfilter, and touch the tubes while the unit is running, if nice and cold, all is well, there just isnt any moisture there. but if compressor is running and tubes are warm , means freon/coolant has leaked out
Jul 22, 2009 | LG LHD65EBL Dehumidifier
Fan runs, but compressor does not start
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Compressor runs, overheats and shuts down..fan does not run...
I have had the same problem. Following the advice of someone on these pages I opened the machine up and checked the fan with a meter. On my model (the 404) it has two settings so two leads; one seemed okay, the other was dead. I checked the circuit where the fan connector plugs in and I got that both speed settings were supplying plenty of juice. Apparently the fan motor is dead. A replacement runs $79 at http://www.appliancefactoryparts.com/. I ordered one; we'll see what happens.
Apr 11, 2009 | Goldstar DH504EL Dehumidifier
Year 2005 cycling fan and compressor
Your unit is probably operating in defrost mode. When you use a dehumidifier in a cold room, the condensing coils can freeze water. The unit senses this and thus stops the compressor until the water frozen on the coils melts. Then it resumes its cycle. This is a problem you will have during the winter months. It makes the operation of the unit inefficient, but this is otherwise normal behavior.
Jan 04, 2009 | LG LD50EL Dehumidifier
Kenmore Dehumidifier
My Kenmore had the problem of the fan running, but not the compressor. The compressor overload part was bad.
Togarba
Aug 27, 2008 | Dehumidifiers
My dehumidifier will not turn on
heatman101
Jun 11, 2008 | Goldstar DH504EL Dehumidifier
Running but not collecting water...
Sorry to be vague in advance. I am a bit confused as to the compressor seems to be running bit. If the unit is on you should hear the compressor making a continuous noise. What you have described over a relay going click every fifteen secs could be the compressor overload / relay. If it is then the compressor is trying to start hence the dimming lights. Either way I would suggest one of two scenarios either the compressor is faulty or cannot start due to the relay or the unit is short of gas. Eiher way not a good scenario. I would suggest a tech to confirm or spend the money towards a new unit. Hope this helps.
Aug 19, 2007 | Maytag M7DH65B2A Dehumidifier
Kenmore 54501 Dehumidifier Logo
343 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
