Question about Vacuums
Won't pump the water out - Vacuums
  • 43,501 Answers
Have no idea what you are working on...
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Posted on May 24, 2011
Won't dispense water
Hey Parker. I know how frustrating no spray can be when you're ready to clean your carpets.
Here's a complete list of troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Bissell PowerSteamer 1697 series won't discharge water. At first it was just the vacuum art now its also the handtool.
You may have problems with your pump belt, gaskets, or tank. Use this link to determine the exact tip to fix your unit: http://www.bissell.com/FAQDetail.aspx?id=1065
If these don't help, please take your unit to a service center for diagnosis and repair. You can visit a BISSELL Authorized Service Center by locating one here: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50
Sep 30, 2012 | Vacuums
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
Rainbow vacuum won't power on.
Do you have it on the water pan? All models above the eSERIES will not run without the water pan.
RainVac
www.rainvac.com
800-523-0510
Jun 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
The water or solution will not shoot out
Good Afternoon! This is a wonderful machine! Unfortunately, the pumps tend to go out. The pump not only releases the hot water to spray, it also controls the release of the cleaning fluid. Most likely you will need to replace the pump. There is an 800 number on the back at it's base. Serial and model numbers as well. You can test the unit to make sure this is the problem. Fill both the bladder and cleaning fluid resevoir and plug the unit in. Turn it on, release the handle and lower the handle to the floor while it's running. It is safe to do this and the brushes will stop rotating. You will see a hole (opening) in which the fluids normally flow. This hole SHOULD have suction when placing an object directly over the hole. Fingers flattened, a paper plate, anything that is twice the size of the opening and solid enough that it can not be sucked into the unit. If there IS suction, next test is to return the handle to the upright position till it clicks in place. Turn the knob selection from floor to tools. Squeeze the fluid release lever while aiming at a paper plate. See if it has sprayed fluid, then release the handle and try sucking up the fluid. If you again have no fluids released, you do need a pump. Check the age of the unit. Bissell has a 2 year Warrantee that usually covers most repairs and the 800 number will give you local repair shops. If you are out of warrantee, the pump can be ordered and installed through Sears for a reasonable price. Once you do this, YES, purchase their extended warrantee, it always pays off because the pumps go out a lot. But hey...they do a beautiful job cleaning! I hope this is helpful. By the way, if it doesn't pick up fluids, be sure to clean the unit thourally. Take pictures on a cell phone to double check how to put the parts back if you're afraid you won't remember OK?
Sep 22, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
