Question about Cepia "" Hands Free Power Sprayer
My sprayer doesn't work at all. Replaced the batteries and and still nothing. I love this thing -- it's so helpful. Any thoughts
I have a 1999 Nissan quest. The front and rear windshield wiper don't work. I can't even hear the motor going just nothing and front and back wiper fluid doesn't turn on either. We checked the...
test the flasher relais and clean it the contacts. test the connector and wires for loose, or corroded. Test the fuse too see the diagram attached.
Jul 08, 2013 | Cars & Trucks
Doesn't cool
You have troubleshot this thing well. You may have a capacitor problem or starter problem. It will not be design let the unit come on. This is all to protect the expensive compressor.
Feb 03, 2013 | Franklin FWC100 Wine Cooler
Rear windshield wiper sprayer doesn't work but the fronts work fine 2002 jeep liberty limited
The rear wiper has its own pump motor. pull the hose from the wiper and have someone engage to see if there is a clog. do the same at the motor. if bo liquid comes out then its the pump. also check fluid level in reservoir as well as a possible secondary reservoir
Dec 01, 2012 | 2002 Jeep Liberty
MY KEY DO NOT LOCK DOORS AND SET ALARM
I would try disconnecting the battery for five minutes like resetting a computer. Replace the battery in key fob. Body computer does strange things with lights hope it doesn't need to be replaced about 350 dollars if you have it replaced and any thing else doesn't work after they replace it tell them. I had two of them replaced for me because they are rebuilt
Jan 11, 2012 | 2004 Chrysler Pacifica
This is the second feeder I've purchased that quits spraying water (anything more than a dribble) after 3 or 4 uses. Even replaced the washer today. There are 6 refill bottles in my garage, but no...
I'm sorry to hear about the problems you are experiencing with your LiquaFeed Sprayer. You can always try to soak the sprayer in warm water for about ten minutes, and wipe dry. If this doesn't help, please call Miracle-Gro at 877-465-5160.
Hilary @Miracle-Gro
Aug 10, 2011 | Scotts Miracle Gro Liquafeed Sprayer 6...
I just changed the batteries and the buttons will do nothing. The menu appears on the screen when the batteries are put in, but I cannot shut it off without removing the batteries. Can I somehow reset...
You can take out the triple a's and leave it sit for a minute or so, if that doesn't work you can do the same thing but take out the small watch battery too. Finally if its still not working you can try calling Ti Cares (800-842-2737), they're usually helpful
Jul 26, 2011 | Texas Instruments TI-89 Calculator
Gritty residue left on dishes. the middle arm doesn't seem to be working
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | Frigidaire Dishwashers
It doesn't work. Got it for Christmas and love this coffee maker but it doesn't work half time. No. Most of the time
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 14, 2011 | Keurig Platinum B70 Coffee Maker
Cepia "" Hands Free Power Sprayer Logo
46 people viewed this question
Top Cepia Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Cepia Garden Expert? Answer questions, earn points and help others
