Question about Stinger Division Of Kaz B4045 4 Black Light Replacement Bulb
How do take apart a stinger bug zapper to change fuse?
I have a flowtron bk-2125 bug zapper, looking at the troubleshooting, it said check for power on the grid, how do i do that. I changed bulb and it is not coming on, it said if i have power then the starter...
If you have no power from the grid then bug zapper is not problem. If bug zapper is a corded plug in application then unplug and plug into a plug in that you know works. Check your breaker panel for a tripped breaker and reset if necessary. Or try a different appliance by plugging something that you know is operational into the same plug. If it works, there is likely an internal problem in bug zapper.
Oct 08, 2014 | Cars & Trucks
How do I install two C batteries correctly into my Stinger hand held bug zapper ?
The flat end of the battery (with out the nipple) normally goes to the spring in any battery holder. There is normally a picture of the battery orientation in the plastic molding of the battery space (sometimes hard to see)
Sep 03, 2014 | Cars & Trucks
When installing the two required C batteries into my new Stinger bug zapper. In what manner should the batteries be inserted into the battery compartment ?
Not sure which model of Stinger bug zapper you have. If you are using C batteries then it could be a portable racket zapper.
Please check model number and compare with list of manuals on this site.
Owner Manuals StingerProducts com
If there are only two batteries then there are 4 ways in which these can go. You could try and see which one works.
Sep 03, 2014 | Camping, Backpacking & Hiking
How to replace battery
It should say on the back where the battery compartment is which way negatives and positives should go, but the one with the spring is negative :)
Hope this helped!
Sep 03, 2014 | Kaz Inc Stinger Flat Panel Bug Zapper
How to repair
Is the buglight still working? I simply take a blade of grass and place in between the wire cages to make electrical connection and verify transducer is not defective. If you don't get a spark quickly your transducer may be burned out as I cannot keep one working due to larger insect getting in unit and overloading the transducer.
May 22, 2014 | Stinger 1 Acre Bug Zapper
Can not find xfmr 400 32 nb transformer
Sears sells them, $40+. They gotta be making a killing.
Apr 16, 2013 | Honeywell Uvb45 Stinger Ultra Bug Zapper
Green light is on, fan is blowing but we know longer smell the ozone from it; we have just changed the plate & cleaned it?
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
Apr 18, 2010 | Ecoquest Living Air Classic Air Purifier
I have a large bugzapper by Stinger. I plugged it
How is the voltage to the zapper, is the circuit ok? Check it on another plug...
Aug 06, 2009 | Electronics - Others
Stinger Division Of Kaz B4045 4 Black Light Replacement Bulb Logo
738 people viewed this question
Top Stinger Camping, Backpacking & Hiking Experts
Shehu Pro
Shehu Pro
Are you a Stinger Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
