Question about Sylvania GNET28001XSN Netbook
Every time i insert my Kingston USB into my net-book it asks me to "Enter the name of the driver for this USB device."It will not except any name i type in for it "Error installing USB driver _______...However, it once allowed me to.Please help me figure out how i can fix this problem. Thanks-T
  • 88 Answers
Sounds as though you might have some corruption on the drive.
Back up all data on the drive to an alternate location and try to format the usb drive partition with Fat or FAT32. This should, hopefully correct the driver problem in windows.
Option 2:
If this does not correct the problem you might check the program access and default settings to verify the defaults for devices.
Option 3:
"WARNING : Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk. If a USB storage device is already installed on the computer"
First is to ensure that the
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\USBSTOR start value is 3.
If you are an administrator on the machine, ensure C:\windows\system32\drivers have SYSTEM user access especially USBSTOR.SYS.
If you don't have usbstor.inf in that directory or anywhere in c:\windows, go download from the web.
Go to Device Manager an uninstall the " ? " which was a result of the failed driver installation.
Plug-in the device, then when asked where to search, point to c:\windows\system32\drivers...
Posted on May 24, 2011
Kingston Datatraveler Windows 7.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
eventhough the device is not present, causing the said error.
Aug 15, 2012 | Kingston Computers & Internet
How to convert 2gb sd card into 4gb
How to convert 1 or 2GB memory stick into 4GB?
Just follow the simple instructions:
Step1: Insert your memory stick in USB port
Step 2: Open the Drive increaser software folder (download the software)
Step 3: Rename the Pendrive or memorystickimage_thumb%25255b35%25255d.png?imgmax=800
Step 4: Open Drive Increaser 2 icon from the Downloaded folder.
Step 5: The opened file is asks USB drive Name. (Before enter the name first Rename the Memory stick or Pen drive). Just enter the renamed pen drive name. Ex: 2341
Step 6: After that, it will ask USB pendrive letter (Ex: H or I or J). Repeat this two times
Step 7: After Drive letter entry some process will be done with Red color like this image
Step 8: Finally it shows Done Please enter any key to done.
Now your Pen drive is 4GB
Jan 12, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hello, I have A 4gb Kingston pendrive. When i connect it to my PC, It show That "USB Device not Recognized" . Please help me what can i do. Please Please...
Apparently, the driver for this device is not on your system. You can have the operating attempt to find a driver on the internet which it still may not find the correct driver, and you may have to go to the link below.
You can right click and select open or double left click on the link. If that does not get you to the site you can select and copy the site address pasting it into your browser address bar and clicking on refresh or go. Select your country and product so you can download the correct driver and save it on your hard drive. When you insert your USB drive it will say the device and not recognized prompting you to indicate where the driver is located. Select to manually locate the driver and use browse the indicate where the Kingston driver was saved. Once the driver is installed in the system directory it will recognize it whenever the USB driver is reinstalled.
Mar 04, 2011 | Garden
I have kingston 2GB pen drive. when i insert this its shown found new hardware yyyyyyyyyyyyyyyyyy............yyyyyyyyyyy USB device when i click on it its gone for driver installation. when i click for...
These kingston pen drives should load without having to find a driver on anything newer than xp and up. try it in a different port on the rear of your machine if possible and make sure you fully seat the stick into the usb port, as this will sometimes cause this problem. once inserted you should be able to browse the kingston drive on "my computer". if not look for a damaged socket or try the key in another computer to verify if it works properly
Aug 29, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
It gives a cod 10. What can I do
If you received a (Code 10) error and have more than one USB device inserted, remove the devices and insert the Kingston DataTraveler by itself. This error may be an indication that your particular system cannot support more than one USB device at a time.
Mar 02, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do i go about formatting my kingston sd card, step-by-step?
Insert card into card reader. Find which drive letter the card is in. Right click on that drive. You will see an option that says format. A warning will tell you anything on the drive will be errased. Once sure you have the right drive click OK.
Nov 28, 2009 | Kingston 4GB Secure Digital High Capacity...
I have two computers one has windows xp and the other has windows 98. I have purchased an 8GB USB FLASH MEMORY with the intention of being able to transfer data from the older computer to the xp one. I see...
Hi bernie_r
It is difficult to find USB FLASH MEMORY to Windows 98, but there are possibilities.
Another thing you can try is to go to the product homepage and see if they have drivers to windows 98 there, many times they give it there. Unfurtunality you have not give the product name so I can not give it to you here, UNLESS you write the product name and version.
For the Kingston USB drives is is :
For one they have driver for windows 98 is "Data Traveller 4 GB", It should be easy to find on the marked
You can also e-mail to them and ask for the driver to windows 98.
Hope that helps
For the driver to your flash drive please enter the product name and version.
Have a nice day
Please rate my answer
Sep 14, 2009 | Computers & Internet
Mar 02, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb not recognised
the connector of you usb port of your unit kinston is need to re_soldering by using a soldering iron.or need to re-heat by hot-air unit.
Jan 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Sylvania GNET28001XSN Netbook Logo
182 people viewed this question
Top Sylvania Computers & Internet Experts
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
