Unable to connect to server to play call of duty 4 netgear wpn824 and wg311
  • 185 Answers
Install the setup with smartwizard @ installation cd then,cofigure the user settings and try,if the problem remains then,switch off the firewall and try again.
Posted on Aug 15, 2008
Can I connect non-wireless printer directly to netgear rangemax wpn824?
No you cannot.
To make your printer a network printer you need to connect your printer to a network print server and the connect the print server to the Netgear using a LAN cable.
Feb 14, 2013 | NetGear RangeMax WPN824 Router
Netgear wpn824 v2 loses connection The internet light blinks amber every few minutes and I lose connection to the internet.
if you're online and loses connection every couple of minutes,that most likely be and issue with you ISP. it's intermittent connection issue with the server or might be the modem if it's more than a year.. better is to contact your ISP to check on their end,also to create a work order to investigate and monitor the issue.
Oct 07, 2011 | NetGear RangeMax WPN824 Wireless Router...
I need settin my modem to my pc netgear wg311
to configure the WG311 on the computer, first instll the adapter using the driver CD. follow the step below to configure wireless connection:
1. Double click on WG311 icon from the right hand extreme bottom corner of the screen, near the system clock, in the system tray.
2. Click on networks tab.
3. Click on the SCAN button - This will show a listing of all available networks.
4. Select the network you wish to connect to and click on the "CONNECT" button.
5. This will automatically take you back to the settings tab.
6. If you are using WEP security then Enter the WEP KEY under the option 'Enter Key manually' under the settings Tab.
7. Apply Settings .
8. This should get you connected to your selected network.
9. Click on the 'About' tab and check the IP address.
10. If you are getting an IP address in the format of 192.168.1.x, try to go online.
11. If you are not getting an IP or the IP is in the format of 169.254.x.x, restart the computer and then try to go online.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 05, 2009 | NetGear WG311 54 Mbps 802.11g Wireless PCI...
Driver Problem
I M NOT INSTALLED THE DRIVER OF NETGEAR WIRELESS WG311 ADAPTER FOR WINDOWS 2003 SERVER. PLZ. GIVE ME A DRIVER FOR WINDOWS 2003 SERVER
Jan 21, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Wireless not working from netgear wg311 to a new bt homehub2
Hi Backatya,
Check what kind of security you upgraded BThomehub 2 uses. Since the hub supports more security-types then your adapter does, I suspect an incompatibility there.
You can solve it by connecting through cable and changing security to WEP or WPA (not WPA2).
Regards Ronnie
Dec 15, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
Weak connection with my xbox 360
The best way to make the wireless connection stable is to do some changes on the wireless settings of the router , like changing its wireless channel to the highest one to avoid any interference on your area.........
Sep 15, 2008 | NetGear RangeMax WPN824 Router
Worked Fine and then my computer did not recive a wireless connection, and nao cant play my 360 :[
make sure the wireless part of the router is working fine by trying a computer to connect wirelessly to the router. if it connected fine then it is a matter of matching the wireless settings of the router and the xbox in order for them to synchronize properly.
Jul 02, 2008 | NetGear RangeMax WPN824 Router
Call of duty 4 connection
When this happens, you need to go to your dashboard because you arent even connected to xbox live. Then, log out and check your xbox live connection. One of the tests will fail and this will be your problem.
May 23, 2008 | Microsoft Xbox 360 Console
Netgear Firewall
with the router connected, open Internet Explorer and type http://192.168.1.1 after you log in there is a option on the left for firewall and you can turn it off. If it were me I would use the routers firewall over a software firewall though. By the time a software firewall detects a hack, its already in the PC.
May 19, 2008 | NetGear RangeMax WPN824 Wireless Router...
Wg311- 54mbps 802 11g/b wireless adapter netgear
you cannot send anything wireless to bluetooth they work on different megahertz, on bluetooth enabled devices can use file transfer
Oct 16, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
