Question about Garden
Ariens riding mower hydrostatic S-16H how do i drain fluid from transmission cant find drain plug
5 Suggested Answers
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
  • 130 Answers
SOURCE: need to find parts for riding mower hydrostatic transmission
yes it can be fix.but it might cost you alot of money.i will try to help you.let me know. want parts you need.i need a pic.i have lots parts.let me know.ok
Posted on Jul 22, 2009
  • 18 Answers
SOURCE: I have an ariens zoom 1540 hydrostatic mower. One
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered.
Posted on Jul 09, 2010
2strokeguy
  • 183 Answers
SOURCE: I have an Ariens YT150H
Make sure that when you reinstalled the rear tire, that you reinstalled the keyway into the axle. I think your wheel is probably just spinning on the axle. Otherwise, did you have to get rough with the wheel to take it off the axle??? Some of these trans have a snap ring on the inside of the unit that holds the axle in place. Hammering on the wheel can often cause the snap ring to come off internally in the trans.
I really hop you just missed putting the keyway back into the axle.
Posted on Sep 20, 2010
Testimonial: "Thank you so much for the quick fix! This was very obvious when I read the suggestion, but it would have cost me time and/or money to figure this out"
Ariens 5 16h ride on ,blown Kohler 16hp engine ,replaced with chinese 13hp,but i think turns in opposite direction ? Will this damage hydrostatic trans ?.? Many thanks Andrew
all engines rotate in a clockwise direction
You will see a lack of performance in the new motor because the original 16 hp was not big enough to do the job
it is good policy when doing a motor transplant to go bigger , not smaller as the money you save on the smaller engine will be lost in the performance difference
Jan 04, 2018 | Ariens Garden
I have aN ARIENS 42" a husqvarna mate. I found a wire off and not sure where it goes, it will not start
that might not have anything to do with your issue. there are plugs that aren't used...
does it crank and not start
or
not crank ???
Oct 20, 2014 | Ariens Riding Lawn Mower. 42 in. 19 HP...
Does arien mower have a hydrostatic transmisson?
Some units do have hydrostatic transmissions, but most of the 42" units have 6 speed geared transmissions. To be absolute, you will need the product number.
Jun 16, 2014 | Ariens 42" Riding Lawn Mower Blade ...
What is a hydrostatic transmisson?
Hydrostatic transmissions are automatic "Hydraulic drive" transmissions. The largest producers of hydrostatic transmissions are Hydro-Gear, Tuff Torque and General Transmissions.
I have Poulan Por 54 inch deck,25 hp Kohler hydrostatic. After I mow on unlevel ground for about 30 min. Transmission makes noise jerks and won't go till it cools off. Will changing the fluid help
couldn't hurt to try but some cheaper mowers don't have a drain plug look on a parts break down on sears parts online but check the belt tension first
Apr 13, 2012 | Garden
The mower gets slower and slower and then stops moving completely. I turn it off for five or ten minutes and it's okay ... occuring more frequently ....
The hydrostat transmission is low on fluid. Check your manual, some of these can be filled...most cannot. If yours can't be filled/doesn't have a fill opening, Husq is going to recommend to replace the transmission (sealed unit). There has been limited success by trying to top off the trans thru the vent tube. This is not a Husq approved repair, and is very slow and tedious. But it is a lot less expensive. Good luck!
Aug 23, 2010 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
I have an ariens zoom 1540 hydrostatic mower. One wheel turns the other does not.
Jun 11, 2010 | Ariens 34 In. Zoom Series Riding Mower
How do I check fluid level on YTH150 Hydrostatic Transaxle?
My Husqvarna hyrdrostatic transmission is sealed, and yours may very well be also. That means no changing the fluid.
May 13, 2009 | Husqvarna Garden
Garden Logo
189 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
