I have an auto attendant message on my inbound lines that I wish to delete. It has a message and a press 1 or 2 option that are cumbersome and not required, how do I get into this function and delete this message/service
  • 1 more comment
  • nautilusreso May 24, 2011
    Hi its an NEC Dterm Series1
    Did you not get my response sent over 5 hours ago as I still do not have an answer? We have an NEC Dterm Series 1
    Yes I did expect a solution i paid for. I answered a follow up question on the type of device and assumed (wrongly) that it would get reclassified as a PABX issue. I have a NEC Dterm series1 unit.
    Guru:
  • 1,833 Answers
If you try to dial 770 to get voice mail to answer, thenpress menu, system program, extensions, more, group calling, line/pool keying770 and press enter - then press Inspect. If calling group 770 hasany lines and/or pool assigned they will show up. Now remove each line and/or poolby keying the line number and or pool number and then pressingdelete. Press Inspect again to make sure all lines/pools areremoved.
Posted on May 25, 2011
  • 2,460 Answers
Take a look at your question again. It may look complete to you, but it's posted under FAX machines and there's never a mention of the PHONE SYSTEM or FAX SYSTEM or anything.
Did you expect a solution?
Posted on May 24, 2011
  • 794 Answers
Hi nautilusreso,
May I have the brand and model of your machine? I'll be waiting for your reply.
Thank you for using FixYa.
NORSTAR M7310, AUTO ATTENDANT...main message is fine, but then I had a message that stated for XXXXX press 1, for xxxxx press 2, for xxxxx press 3, etc... I have lost that message I recorded and it has...
Check the greeting table for the line to find what greeting it might be using 1, 2, etc. this might be where your strange message is located and the AA is using it instead of the CCR 1.
Sep 30, 2013 | NorStar M7310 Corded Phone
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
I can not change the Auto Attendant Message on the phone . It wont let me change the auto-attandant message i put in the password as 1020000 and it says invalid! how can i get around it...no one knows the...
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Sep 15, 2009 | NorStar M7310 Corded Phone
Direct transfer
Selector Code 1 and 2 have to be deleted or disabled from Auto Attendant.
Login to your voicemail admin box, go to Auto Attendant menu--- selector code assignments are in there.
Jun 02, 2009 | Avaya Corded Phone avaparp18d
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
AT T 984
I was told by an AT&T rep that the auto attendant can forward calls to another 984 phone to leave messages for that person. Your original OGM (out going message) on the designated Auto Attendant phone should state greeting and the names and the extensions. The caller presses the buttons for the person they want to reach and their call is forwarded to that extension. That extension, if unattended, will have an OGM telling the calling who they have reached and to leave a message. This feature can only transfer calls to other 984 phones only.
Jan 06, 2009 | AT&T 984 Corded Phone (att00148)
51 people viewed this question
jasbo
jasbo
