Question about Jenn-Air JCD2389G Side by Side Refrigerator
The temperature in the refrigerator side has slowly gotten warmer to where it's now at 50 with max
  • Jenn-Air Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 24, 2011
Water going to filter but no coming out to fill your glass
FROZEN LINE IN THE DOOR. TRY TO PUT TEMPERATURE IN FREEZER TO MAX (WARMER) LET IT RUN LIKE THAT FOR A WEEK. IT SHOULD HELP.
Jan 26, 2014 | GE GSL22JFXLB (22 cu ft) Side by Side...
Maytag side by side, freezer working fine, refrigerator not cooling.
If your freezer side is capable of making ice, and that ice is dry and remains so,
the only issue you have is insufficient airflow to the reefer box section from the freezer.
The refrigerator section is 100% reliant upon the frezers side for all of its cold air.
The refer box has no evaportator of its own, There are 2 settings or dials.
One is the temperature thermostat, it actually controls the compresssor motors cycling,
thus the desired ice box temperature as well, it often says 1-10 and off as well, the reamaining setting, the one that cannot turn the compressor motor either off nor on is a damper door controller, that modulates the freezers airflow into the reefers box!This is where the problems occur, when one notices the reefers box is warm, they max both settings,which seems logical , and is for the thermostat dials setting.Where the major counter intuitive reality exists is the flapper dooors setting will say Colder and Warmer!!Colder of course!! right?? No, it actually means and usually does say, Colder Freezer!!not Colder Reefer! so you MAX or RAISE the thermostat, thats ok to do.But maxing or raising the other setting is just starving the reefer box section from sufficient cold air flow to maintain adequate temps.I have gone to hundreds of identical calls, Freezers ok, but Reefers warm! If the freezers making ice and the ice is dry, there is no problem with the refrigeration system, its airflow.when defrost timers or heaters fail the symptoms may be as yours, however the freezer will slowly warm in another day or so. But if the freezers making ice for days and never getting wet theres an airflow issue period, you may need to remove the back wall panel in the freeezer to see the coils condition , is it iced up or blocking airflow with icing/ is the ducting open between the freezer and reefer boxes?setting both dials to the midway setting should work fine. the condenser coils may be dirty/dusty too, is the cardboard backing still in place on back? it needs to be there intact.
is there product inside the reefer box? if not add 3 gallons of water.
Dec 27, 2010 | Maytag MSD2355HES Side by Side...
Fridge not keeping cold whats the best temp. we only have no.s 1 to 10.
The refrigerator section is 1005 reliant upon the frezers side for all of its cold air.
1 is the temperature thermostat, it actually controls the compresssor motors cycling,
thus box temperature as well, it often says 1-10 and off as well, the reamining setting, the one that cannot turn the compressor motor either off nor on is a damper door controller, that modulates the freezers airflow into the refers box!
This is where the problems occur, when one notices the reefers box warm they max both settings,
not colder reefer! so you max or raise the thermostat, thats ok to do.
when defrost timers or heaters fail the symptoms may be as yours, however the freezer will slowly warm too much in another day or so. But if the freezers making ice for days and never getting wet theres a airflow issue period, you may need to remove the back wall panel in the freeezer to see the coils condition , is it icedd up or blocking airflow with icing/ is the ducting open between the freezer and reefer boxes?
is there product inside the reefer box? if not add 3 gallons water.
Dec 27, 2010 | GE Profile PSI23NCR Side by Side...
Ice cube maker makes ice cubes ever once and a while, the condenser fan turns slowly. is this why it doesn't make ice cubes and the frezzer side is not cold enough? condenser fan going out? monogram...
Good day,
The ice maker speed of production is determined by the freezer temperature. If the freezer temperature is warmer than normal then the cycle thermostat in the ice maker will take longer to reset for the next harvest, causing low ice production.
More important, the condenser fan motor running too slowly can cause the compressor to run overheated and cause serious and expensive damage.
If in your opinion, it is running too slow, the issue should be addressed as soon as possible.
Aug 05, 2010 | GE Monogram ZISS480DRSS Stainless Steel
GE GSS25LGMFWW side by side. Freezer will run till iced up then defrost everything in the freezer compartment. Why is it doing this?
hi, have you try adjusting the temperature:
To change the temperature, press and release the
WARMER or COLDER pad. The SET light will come
on and the display will show the set temperature.
To change the temperature, tap either the
WARMER or COLDER pad until the desired
temperature is displayed. The
freezer temperatures can be adjusted between
–6°F and +6°F.
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The temp alarm is sounding
Auto defrost system not working properly
staying in defrost to long,door gasket leak
compressor overheat,controls turned up max
all above can cause your problem
even cloged defrost drain
Apr 28, 2010 | Kenmore 57029 Side by Side Refrigerator
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
I have ED25PQXDW01 Whirlpool refrigerator. Both
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jan 05, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
63 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
