Question about Oniss Paris ON833L7 Watch for Women
I have a Oniss ceramic watch and the instructions does not tell you how to remove links to shorten the the band. Any help is appreciated and thanks.
escapement
  • 2334 Answers
SOURCE: How do I shorten the watch band?
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 28, 2009
  • 51 Answers
SOURCE: shorten watchband
You can find here step-by-step instructions with pictures:
How to shorten a metal watchband
It is for a casio watch, but the watchband has the same principle with "arrows" on the links.
Posted on Sep 13, 2008
escapement
  • 2334 Answers
SOURCE: Can not figure out how to remove links from Casio watch band
Job done!
Posted on Apr 01, 2009
SOURCE: I need to shorten the metal link watch band of my
I just looked at the watch band link more closely and figured out how to remove the links. Pretty engenious link attachment arrangement!
I thought there would be something in the watch manual about band adjustment, but there wasn't. I guess it is not something a "normal" person would be able to do.
Thanks,
Steve Zansler
Posted on Jan 02, 2010
disap1
  • 98 Answers
SOURCE: i have a michael kors white ceramic watch and the
Ceramic links break VERY VERY Easily!!! Take your watch to a reputable watch repair shop and have them adjust your watch band! :-)
Posted on Jan 16, 2010
I have a men's Oniss watch ON 524m and the band is cracked and broken. Can it be replaced?
You may be able to get a band from a jeweler but im not too sure of your chances.... perhaps contact Oniss and they should be able to help maybe :)
May 07, 2017 | Oniss Watches
I need to take links out of Oniss ceramic watch
Take it to a dealer, a specialist or return it to the retailer and pay to have the bracelet adjusted so you won't have liability for any damage.
Dec 28, 2016 | Oniss Watches
Where would I get a pin that fixes the bracelet to the watch lugs of the following Ceramic Oniss Paris watch. Its rose gold in colour
This is a standard item irrespective of the watch it is for. Just go into any reputable jeweler and they will put it on your watch for about 5 bucks.
Dec 02, 2015 | Oniss Watches
How to take links out of watch band.
there are little holes on the sides,use a tack to push it out on the side,if it doesnt come out on 1 side use the other, https://www.bing.com/videos/search?q=watch+band+pin+removal&FORM=HDRSC3
Jul 18, 2015 | Oniss Paris Womens On626-LRG-BLK Meduse...
How do I replace the battery on my Oniss 612 L
take it to a walmart store and have them do it . unless of course you have a case press to put the back , back on with
Mar 03, 2015 | Oniss Ceramic Watches, Ladies Tungsten...
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
Hey there, I just got an Oniss white ceramic watch for my birthday and I raced out to have links removed. No one can do it - two fine jewelry stores and one watch repair place. They said the don't have a...
Wow. Unusual for those places to not be able to do it. The only suggestion I can find since you did exactly what I would have told you (jeweler/watchmaker) I would try the following link:
http://www.watchrepairsusa.com/oniss/watch-repair
Sorry. Best I can come up with unless someone else has some ideals. Good luck.
Aug 13, 2010 | Watches
Remove links on a ceramic Oniss Watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to remove or add links.. Rate me, please .
Apr 14, 2010 | Watches
Oniss Paris ON833L7 Watch for Women Logo
131 people viewed this question
Top Oniss Watches Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you an Oniss Watch Expert? Answer questions, earn points and help others
