Question about Motorola Mobility RAZR V3
Red Power Key not operating properly. . won't power off or end a call.
On my MOTO Razr, the red power key not ending call.  Also, I get no battery indicator, although I can still send - receive calls. . . just can't end them.
  • bpowell627 Sep 28, 2008
    Phone will power off by red power key. Can't end a call with the power button or by closing phone.
  • 3 Answers
Just close your phone to end your call. make sure speakerphone is off
Posted on Aug 17, 2008
Phone has switched off and wont restart
try taking the battery out for 5 or 10 seconds then put battery back in. Hold the red power/end key down. If that doesn't work see if it will power on while charging.
Oct 30, 2012 | Motorola Mobility RAZR V3
Tip
How to reset Kyocera Zio m6000
Soft reset
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
Hard reset
1. Power down the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
To reset Kyocera Zio try the following:
1. Remove battery and put it back after two minutes
2. Press and hold down the home button key while turning on the phone.
3. If by chance the phone starts , do Menu Button > Settings > SD Card USB MASS > Factory Data Reset
If it does not work, try:
Hard reset 2.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
3. Allow the phone to completely reboot. This may take a few moments.
4. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
If still no luck, call Kyocera directlyand report the problem.
on Sep 03, 2010 | Cell Phones
How to reset sanzo zio phone
WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
a)
b)
Procedure, cont.
8. Allow the phone to completely reboot. This may take a few moments.
9. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
Dec 02, 2011 | Sanyo Cell Phones
How to reset cricket zio
a)
b)
Procedure, cont.
NOTE: If you receive a self-test screen or blue screen, the hard reset was done incorrectly. Please try again, from step 1.
Dec 02, 2011 | Cell Phones
My kyocera sanyo cricket phone screen is locked how to unlock it
Hard Reset.
1. Turn off the phone
Phone is completely reset as if it came out of the box. You'll need to *228 and reload ALL of your data.
or WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
a)
b)
Procedure,
Sep 12, 2011 | Kyocera Zio M6000 Cricket
I need to hard reset my sonyo zio
Zio Hard Reset From Cricket corporate
a)
b)
Procedure, cont.
Nov 17, 2010 | Google Android
I can't find the button to turn it on. i don't know which one it is, rather
Most phone's power button is the RED End Call button. Just hold it down for a brief couple of seconds and it should turn on. Be sure the battery is charged or your phone is plugged in.
Feb 10, 2010 | Samsung UpStage SPH-m620 Cellular Phone
Which is the on button for the Razor?
The power on off button is the red end key on the Razr
Jan 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Unlocking my phone?
press the power button, as the q is booting up press the silver button and the red power button (end key) at the same time. Hold for a few seconds. This is a master reset.
Feb 20, 2008 | Motorola Mobility Moto Q
Motorola Mobility RAZR V3 Logo
53 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
