Question about Denon Audio Players & Recorders
Is there anyway to repair the foam earpiece on denon ah-d210 over the ear headphones?
  • Denon Master
  • 5,190 Answers
Have a look at my tip on headphone problems just click my user name to find it, you will find an answer at the bottom of it.
Posted on May 26, 2011
I cannot connect my iPod nano with Bluetooth to my Denon AH-W150 bluetooth headphones. Help!
that is because the ipod nano can not connect to bluetooth it does not have a bluetooth reciver
Sep 07, 2013 | Denon AH-W150 Exercise Freaktm Bluetooth...
Jvc headphones retractable cord
The JVC HA-NC250s are a new version of their previous model 100, and JVC claims that they will cancel up to 85% of ambient noise, coupled with better sound. In this case, JVC claims up to 16.5 db reduction at 150 kHz. These on-the-ear headphones are very lightweight at 5.3 ounces and are extremely comfortable. The head band has a reasonable amount of sliding expansion for bigger heads, and the oblong ear pieces themselves rotate and fold flat for storage. JVC uses memory foam on the earpieces, as well as double housing, for extra noise isolation. The earpieces have 40 mm neodymium drivers, which are the same size and type that the Creative Aurvanas offer.The JVC HA-NC250 noise canceling headphones. Note the ear-cushion instruction tab that explains how to replace the hidden battery.
The NC250s come in a semi-rigid black case with a dual airline-plug adapter, a mini-to-RCA phono plug adapter and a 4' detachable headphone cord. JVC includes one AAA battery, which should last approximately 50 hours. A simple sliding switch on the right side turns the noise reduction on along with a small red LED. Learning how to add the battery to the headphones required that I study JVC's user manual. The process involves having to remove the earpiece covering to get to the battery compartment, which isn't at all obvious.
Jul 22, 2012 | Audio Players & Recorders
How to open ear piece on denon ah-d310 headphones?
hey ! of course it's possible to open the ear piece !!!!!
all you have to do is to pull the foam off (it's not too hard :)
then you'll have to unscrew 3 tiny screws (get a really tiny screwdriver....and voila :)
i just did it on mine couple of minutes ago
May 03, 2012 | Audio Players & Recorders
One earbud has stopped working
Common causes:
a) Break in wire leading to the earbud.
b) Defect in the plug at the end of the wires.
c) The earbud transducer unit (part that fits to the ear) has become defective.
Since these are not practical to be serviced, the solution is to replace it...
Jerry G.
Dec 04, 2011 | Denon AH-C260 Headphones
How do you open earpiece for troubleshooting no sound from right side and something rattling around
What you do is peel back the cusion of the ear pad. You might need to tear off the foam covering. You can glue it back on when your done with Bostick white glue. With the coverings gone you should see access screws.
Jan 30, 2011 | Samson CH700 Professional Headphones
I only hear out of the left ear----i believe the problem is from the jack
Please check also the cables for defective together with jack for malfunction
Jan 26, 2011 | Denon AH-D1000 Headphones
My Motorola S305 stereo bluetooth headphones' foam pads on one of the ears is falling off. I've tried using something like a credit card to pinch the foam back into the game where it seems to be held in,...
Hey, this might be too late to help you, but I figured I'd share in case anyone else came across this while looking for help (as I did).
There's a small inner ring that the edge of the foam ear pads wraps around, but you can't really fit it under there while it's attached to the earpiece. The solution? I used something thin (specifically a nail file) to remove this "ring". It actually seems designed to pop on and off. I was then able to easily wrap the foam ear pad around the ring, then re-attach the ring to the rest of the earpiece.
Hope that helps!
Sep 28, 2010 | Motorola Stereo Bluetooth Headphones
I have AH-D210 headphones and the wires have been cut. Can the end piece(jack)be attached to the cut end?
If the cord is long enough take the foam ear protector off the left phone and look for screws on the speaker plate. Once the speaker is exposed take note of the colors of the insulation to each wire. The right side will have a separate wire running from a junction point to the lright phone.
Jul 08, 2009 | Audio Players & Recorders
Wire loose
If you can carefully take the foam earpad off you might find screws holding the speaker plate to the cup.
May 11, 2009 | Altec Lansing AHP712i Consumer Headphones
728 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
