Question about Ricoh Aficio SP C222SF All-In-One Laser Printer
Error Message on Ricoh Aficio Sp C222SF, says FM
EmmettPinger
  • 63 Answers
SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Posted on May 04, 2009
  • 46 Answers
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Posted on Aug 28, 2009
  • 903 Answers
SOURCE: With colour output from a Ricoh SP C222SF Aficio
Are the lines dark or light? You can try replacing the toner to see if that clears it up.
Also, go into the user options -- if you see a setting for something like "toner save mode" turn it off. That can cause poor copy quality and is sometimes turned on by default.
Posted on May 29, 2010
  • 903 Answers
SOURCE: RICOH SP C222SF SC300ERROR WHAT IS IT. CAN IT BE
SC300 on a C222SF is a high voltage power error. You could reseating the connectors for the high voltage power supply and the engine board (EGB), but more than likely one of those two boards will need to be replaced.
Posted on Jun 03, 2010
bosegautam11
SOURCE: Ricoh Aficio SP C411dn error SC542
Ricoh Aficio error SC542
Posted on Sep 26, 2011
Ricoh Aficio SP 4100N SC 590 power off on
YOU DONT FOLLOW INSTRUCTIONS VERY WELL,,DO YOU???!!! CALL SERVICE PROVIDER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Aug 13, 2012 | Ricoh Aficio SP 4100N Laser Printer
Error code sc542 on ricoh spc222sf?????????????????
Press the red CLEAR/STOP key till you hear the little beep. Press 1 0 7 Press the green COLOR START key. The display changes into MAINTENANCE MODE Use arrow keys to go to ENGINE MAINTENANCE and hit Ok Use the arrow keys and select FUSER SC RESET and hit Ok Hit OK again at the Execute prompt.
Once it is done executing the reset, power the unit off and on.
If the error comes back again, it is likely a real hardware problem and you may need to replace some components.
Sep 30, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
May 25, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Ricoh SP c222sf is not recognizing that there is paper in Tray 1 or bypass - tried to rest tray 1 and turn on/off, but the display still shows that there is no paper. What else can I try?
There is a paper detect sensor which sits in the frame of the machine above the paper tray. Pull the paper tray out and make sure this sensor didn't get broken or knocked out of place. (If you have a can of compressed air, shoot some into the sensor to get rid of possible paper dust.)
Mar 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Sc300 service call
On the SP C222SF, sc300 is a high voltage output error. More than likely, either the high voltage supply board (HVSB) or engine board (EGB) is bad and needs to be replaced. However, before going that far, you can try turning off and unplugging the machine and reseating the connectors that go to those two boards. Sometimes a loose connector can cause a service code, and fixing the connection can clear the problem up.
Feb 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
SP C222SF multifunction Printer Problem
Dear colleagues,
I have aficio spc 232, when powering on, it stays displaying initialization message and never comes redy.
Please any one can help me to solve this problem.
Many thanks in advance
Boualem
UAE
May 08, 2009 | Ricoh Aficio SP C222SF All-In-One Laser...
Apr 20, 2009 | Ricoh Aficio SP C210 Laser Printer
Ricoh Aficio SP C222SF All-In-One Laser Printer Logo
101 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
