Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
INNER SCREEN NEEDS CLEANING
DONT KNOW HOW TO TAKE APRT TV TO CLEAN INNER SCREEN
  • 2 more comments
  • BADABING23 Aug 15, 2008
    THIS IS A TOSHIBA 51H84 TV...
    I HAVE TAKEN ALL 10 SCREWS OUT OF THE BACK AND STILL WONT COME OFF..
    TKS MUCHO!! THE SCREEN WILL NEED TO BE REPLACED AS THERE IS A STAIN ON IT THAT WONT COME OFF. DO YOU KNOW WHERE I CAN FIND A REPLACEMENT??
    TKS
    JOE
    THIS SITE IS GREAT!! TKS MUCH FOR ALL YOUR HELP....
  • 2,326 Answers
Here is a picture that shows you how to remove the front screen to get access to the mirror as well.
Posted on Aug 15, 2008
  • Jaime Hernandez Aug 15, 2008
    Have you seen the picture I've posted?
    It shows that the front will need to be removed not from the back.
    Click here to find out if they have the screen. According to the website search, is in stock.
    Good Luck.
  • 10,594 Answers
Its very easy, see its rear side, you will see screws there, unscrew it and remove back cover of TV to clean it. Please you must Unplug TV from AC outlet before open it back cover.
  • Shahid Electronics
    Shahid Electronics Aug 15, 2008
    Jaime867 solution is best, shows exploded view of your tv.
  • Toshiba Master
  • 6,487 Answers
You can check this link for the screen replacement http://tacpservice.toshiba.com/ConsumerProductSupport/consumer_parts.htm
Hope that helps..........
    Master:
  • 521 Answers
Wat model is it
How do I clean my lg screen on my tv properly
Hello
Buy one Bottle of Monster ScreenClean Home & Office Display Cleaner
Make sure your TV screen is completely cooled before cleaning. Have TV turned off for about 30 minutes before cleaning to allow screen to cool off. Unplug TV. Make sure the area where TV is located is well lighted. This will make it easier for you to see if you are leaving any smudges behind when you clean your TV screen. I suggest you get a Monster ScreenClean Display Cleaning Kit, unless you have a couple of clean and quality Microfiber cloths in your home. If so, you can buy the ScreenClean solution separately. Some LCD TVs come with a Microfiber cloth, but they are usually a bit small
Spray Monster ScreenClean to Center of TV
Assuming you are using the Monster brand display cleaner, remove the little plastic cap on top of the bottle pump. Please do not try to go cheap with display cleaning solution when you most likely have a not so cheap TV. The cleaning solution will be much cheaper than having your screen repaired or replaced. The Monster directions state to either spray the ScreenClean solution onto the Microfiber cloth or directly onto display surface. Although the Monster solution is drip resistant, it does trickle sometimes, although very slowly. For that reason, I suggest if you are going to spray your screen directly with the Monster solution, spray toward the center of the TV screen about 8 inches away from the surface. Do not worry, if you forget and spray the solution closer to the frame of the TV, the display cleaning solution is still rather slow in to trickle down your screen. Just use a little caution
Gently rub Microfiber cloth in a circular motion to apply the cleaning solution evenly over entire display. Repeat with dry portion of the Microfiber cloth if the TV screen needs extra polishing. You may get a smudge free cleaning without the dry portion of your cloth if your TV screen was not that dirty
To clean the frame of most LCD and plasma TVs use a clean eye glass cloth dampened with water. Make sure to go in one direction around the frame of the TV. Check manufacturers directions to be certain, but for most the eye glass cloth should be fine. Since it is made to take care of eye glasses, it does not scratch. For certain it works fine on the Samsung Touch of Color TV frames
May 13, 2011 | LG Televison & Video
I was given a big screen Magnavox TV model #38346033. I don't know how to clean the screen. Also the screen has red, green and blue that needs to converge and I don't know how. I don't have the remote or...
Hello linda, hi, I dont think the remote or manual can help the color issue problem, the tv needs to be looked at by a qualified technician. If the TV is a tube type, there are magnets on the neck that needs alignment, this alignment is done while the TV is ON. so high voltage risk are likely. keep out and call service.
Jun 15, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How to clean a toshiba tv screen model # 50a62
snap off the fron cover its pretty tight so kind of pull hard dont worry it wont break its just snaped on tightly, after uncrew 3 screws under the screen lift up and pull out screen there will be 2 wires attached to screen, unplug them to set screen to side. dust off the projectors with dry rag, then clean mirror with windex or any window cleaning product. u are done cleaning front of Toshiba, put everything back together, then unscrew the bottom back and vaccum any dust balls u will see inside T.V. u r now done! let me know how it went.
Jan 29, 2010 | Toshiba 50A62 50" Rear Projection...
NEED TO REMOVE INNER SCREEN.
take the lower panel speaker covers off first, then tanke the 4 screws out below the screen, then take the bottom skeleton cover off around the speakers then you can take the 4 screws out of the bottom of the screen then the whole screen slides up with 4 tabs in all 4 corners becarefull not to pull out the plastic holders will break you need to make sure to slide it upwardes then you have full access to the inside to clean. hope this works for you
Dec 29, 2009 | Toshiba TZ50V51 50" Rear Projection...
Idles at full throttle
Be sure the throttle cable is routed correctly and is not being stretched. When disconnected from the carb, does the inner throttle cable operate freely? Lubricate it. Also check that the cable connections at throttle and carb are seated properly. Does the slide move up and down freely? Remove the air filter and twist the throttle while looking inside the throat of the carb. LIGHTLY seat the throttle screw and the air screw then open each of them one and one half turns outward.
Aug 02, 2009 | 2002 Honda CR 250 R
The screen on our 52 inch TV needs cleaning-inside and out
The outer screen is a protective screen. it is just glorified plexiglass. just use a soft cloth slightly damp.
Apr 09, 2009 | RCA D52W19 52" Rear Projection Television
Cleaning tv screen protector cover
MAKE SURE YOU USE A LINT FREE CLOTH AND NO ALCOHOL OR OTHER CLEANING PRODUCTS,IF ITS A LCD I WOULD'NT RECAMEND TAKING THE COVER OFF
Mar 07, 2009 | Televison & Video
How do i clean my screen
You can clean the screen from the back - take off the access panel. I clean mine once a year whether it needs it or not.
Apr 23, 2008 | Sony KP-53V80 53" Rear Projection...
Cleaning tv screen
need to know how to clean a hitachi rear projection screen tv
Mar 05, 2008 | Hitachi 61SDX01B 61" Rear Projection...
PT5299HD screen
I had the same problem trying to find a new screen. What I did was found a local plastics shop and had a piece of 1/8" plexy glass that has one side anti-glare. It was only $50, and its alot more durable.I had a few problems changing it though. First you have to pull the rear bottom panel lose, then the rear top. Once the screen is exposed (TAKE THIS ADVICE), put a small piece of tape on one of the top corners and mark its position. This has a two part screen and the inner one is a image magnifier and goes only one way. It took me 4 trys to reposition it right for a correct picture. Once you do this carefully unbolt the two side and top screen brackets. Make sure you dont mess with the four centering sensers. Only loosen the screws on the bottom screen bracket. Take the screen out and seperate the two screens by removing the tape around the edges. You will now discover that only the outer antiglare screen is craked. Clean the three inner sides with windex and a paper towel, then use a cotton rag or tee shirt to eliminate any particles left behind. Once you get the screen in place dont over tighten the screws they strip very easy. Since you have the tv apart you should go ahead and blow all the componits off with a keyboard cleaner, and clean the bulbs with a super soft cotton teeshirt with a small spray of the windex on it, dont spray the bulbs directly, and do the same with the mirror. Remeber that all streaks will show up on the image screen. Clean the out side of the screen after you put it back together. Oh yeah, make sure its unpluged first.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
323 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
