Question about Danby DDR5009REE Dehumidifier
Units is running but there is not any water being collected?
    President:
  • 2,080 Answers
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance.
If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room is probably just relatively low and you probably have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room if necessary. A dehumidifier will not work properly if the ambient air temperature is too low. Basically, the warmer and more humid the room is, the better they work.Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where the air is warmer.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
Hope that was helpful. Thank you very much and good luck.
Joe.
Posted on May 24, 2011
How do i fix it so that it will collect water?
1st ck that your humidistat is set correcly and unit cycles the compressor on/off correctly ,Not just the cirulation fan running all the time , next ck your filters , clogged up filters wont allow air to pull thru unit , also are you sure room has enough moisture in it to pull water from, Most units wont draw a percievable amount of water out of air thats got less than 52%rh , as most homes target a 70%rH as normal
Dec 18, 2014 | Dehumidifiers
Freezing problwm; very small amount of water was collected.
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
Dehumidifer Runs but doesn't collect water
Depends on he conditions of the water. These units are relatively inexpensive and typically do not justify the expense of repair. I'ld donate it to an air conditioning school and buy another one.
Jul 18, 2010 | Whirlpool AD40USR Dehumidifier
Unit is running but not collecting water
the units sealed refrigerant system has leaked out and you need to have it repaired,and recharged
May 27, 2010 | Comfort-Aire HD-651 Dehumidifier
DH504EL Unit runs but does not collect water
Demumidifiers are small air comdition units with heaters. Without the change of temp they won't work. Units are often neglected and get pluged up so clean and test the air flow. The filter slowes the air speed down for the process to work properly. Finally the units run better if balanced but slightly tipped twards the drip side. You may need a bigger unit the compresser should cycle (it needs to turn off once in a while)
Aug 18, 2009 | Goldstar DH504EL Dehumidifier
Won't collect water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Mar 11, 2009 | Goldstar DH304 Dehumidifier
Fan runs, no water collected
It appears that these units have a history of defectiveness. I bought one in late 2010 and it pooped early 2012. If the model is still made, buy a new one, return the defective one in the new unit's packing materials for a refund. Or keep the second (new) unit as a back-up, because the new (first) one may just fail again a short while later.
Oct 05, 2008 | Soleus CFM-40 Dehumidifier
Not working
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
Aug 27, 2008 | Dehumidifiers
No water colledction
Check to see that the air is flowing freely through the dehumidifier. They will accumulate dust particles and become plugged. Also make sure that it is not freezing up (you would see ice forming inside through the vent openings). I have had to remove the case to clean lint from some units to get them to operate more efficently. Always unplug the unit to clean and service it.
Dec 31, 2007 | Crosley MCR40ES Dehumidifier
Leaks water
The water may be condensation dripping in an area where the catch components are not able to catch it. The largest line that exits the cold coil and ends at the compressor should be insulated without any tubing showing all the way back to the compressor, deficits in the insulation (even small ones) could cause condensation to form and drip.
Mar 09, 2017 | Goldstar DH5010B Dehumidifier
Danby DDR5009REE Dehumidifier Logo
327 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
