Question about Naxa Electronics NTD1351 LCD TV
When tv is turned on the picture comes up as negative like. After unpluging and restarting the picture sometimes corrects itself. Very annoying.
  • 373 Answers
I would take the back off and unplug all the plugs that go to all the boards and plug them back up. This is the first thing I would do. If this did not fix the problem, then I would do a search on the internet for the main board (the board that has the tuner which the coax hooks up to). Just do a Google, Yahoo, Ebay, or Bing search with the model number.
Posted on May 24, 2011
When I turn on my Philips rear projection tv, the power comes on but no picture or sound. power light stays lit solid. If i adjust slowly the screen or focus controls, the picture and sound will come on....
could be a number of things....check for bad solder connections on circuit board around Flyback xformer and also check connections on conversion module for colour problems....double images red , blue , green popping in and out.
May 19, 2010 | Philips 60PP9352 60" Rear Projection...
My tv will come on with sound but no picture
This is annoying, but common. There is a delay to the backlight that sometimes seems to get stuck and can usually be resolved by restarting right after you turn it off.
If it wont light up at all, you may need a new inverter depending on how old the set is.
Mar 07, 2010 | Mitsubishi VS-4543 45" TV
I hope you can help me.. I own a Samsung DLP TV model no. HL56A650C1F, 56". The problem I am having is that it just turns off by itself and attempts to restart itself continuously. I hear all of the...
I hope you can help me.. I own a Samsung DLP TV model no. HL56A650C1F, 56". The problem I am having is that it just turns off by itself and lights "stand by" and "lamp" are flashing at same time.Sometimes, when I'm trying to turn it on- it shuts off by it self.
Mar 05, 2009 | Televison & Video
TV Question??? Samsung HLN4365W
its either the wire connection CN108 on the DMD is loose or the DMD or power supply is defective. I ten d to believe its the connection since it works sporadically. If replugging the connector doesnt solve the problem you may need to do a step by step diagnostics. Do you have the training manual for the samsung DLPs its actually a very easy process to diagnose with the training manual.
Nov 24, 2008 | Televison & Video
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
1/3 of picture becomes partially scrambled
sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Jun 02, 2007 | Sony KV-35S26 35" TV
KV-XJ29M50 29" TV-Loud thumping sound on startup
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Sep 22, 2006 | Sony KV-XJ29M50 29" TV
Naxa Electronics NTD1351 LCD TV Logo
66 people viewed this question
Top Naxa Electronics Televison & Video Experts
Joseph Gallucci
Are you a Naxa Electronics Televison and Video Expert? Answer questions, earn points and help others
