Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Pink and green stripes across tv screen
Stripes are sometimes wide, thin, vertical, diagonal, and change in intensity. the longer the tv is on the worse it seems to get.
    Master:
  • 623 Answers
I think this is just a case of a poorly designed tv can i have the model# and brand of the set?
Posted on Aug 20, 2008
    Genius:
  • 1,011 Answers
Dear Sir/madam,
This sounds like convergence trouble.Try doing a autoconvergence in your customer menu.If this doesn't correct the problem,call customer service.Is it under warranty?If not will recommend a authorized service center in your area.If the warranty recently expired,you could possibly get company to pay for a "one time service authorization"for your satisfaction.
thanks
good luck
  • Panasonic Master
  • 19,396 Answers
Did you try to check eventual connections to cable box, set top box etc. cable problems can cause same phoenomena sometimes.
  • Ginko
    Ginko Aug 20, 2008
    If your model has balance button, try using it.
    Try also unplugging TV for one hour or so, if you did not do it before, this will reset TV eeproms in case it is a chip problem.
    More likely you will need to adjust convergence/voltage and ray gun projection adjustment, this procedure will require opening the tv and accessing to adjustment controls, and must be performed by a technician.
    Here is an example of RGB / voltage / convergence adjustement performed on a different model. The whole procedure for your model is illustrated in the Service manual.
    DIY on TVs involve hazards and the risk of causing more damage to your TV, unless you can fix it with the simple procedure listed at start, my suggestion is calling a technician for repair.
  • Ginko
    Ginko Aug 20, 2008
    Well.. Panasonic PT-50LC13 is known for being an excellent tv set..with all respect for other expert it is not "poorly designed" at all, and generally it is worth repairing.
    Regards
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
Wide gray bar with thin green, yellow, pink and blue stripes appears when tv is on.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 17, 2015 | Televison & Video
Display issues
no photo posted, of bad screen, why? why make help blind?
the display LCD is bad.
or is the 2008 , solderballs Nvidia chip failure.
if the screen fails in BIOS (press f10 or ESC to enter setup
an fails under boot CD linux or any kind the screen is bad
test with big battery out, always. run on AC power only to test.
do the funny LINES change if you gently twist screen case?
i see reviews on this LT back to 2009
the vista review page on its support pages is stamped 2008
oops !
the BIOS screens are here. hit ESC then F10
dv7-1245dx
this is called hp setup, its BIOS.
if these screens look bad, bingo for bad screen LCD or the GPU.
http://h10032.www1.hp.com/ctg/Manual/c01662442
Jan 01, 2018 | HP Pavilion dv7-1245dx Notebook
Pink and green diagonal lines rollng across the screen??? panasonic 42" Plasma . Only purchased about 3 years ago - but been used very rarely.
Have you tried lifting the ground on the TV? That set has a grounded (3-prong) plug and sometimes sccrolling lines can be caused by a ground loop in your power lines.Are the green and purple lines very short, like just a few rows of pixels tall, or multiple inches, like 3 - 8 tall?
May 04, 2011 | Panasonic TH-42PZ800U Plasma TV
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
Dec 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
My zenith D52WLCD has a blue haze going diagonally
This a Normal Intensive Use Defects, this a Screen Burnout. Sorry
Oct 31, 2009 | Zenith Televison & Video
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
POP and noothiing
yes it can still be fixed! the pop sound you've heard maybe came from a blown capacitor in the vertical deflection circuits. this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 10, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
156 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
