Recently repaired a fault in korg pa1x pro keyboard by changing board. keyboard now booting up and playing only touch screen is now glowing orange and is blank. there are no cables unplugged from screen and contrast does not work
    Master:
  • 521 Answers
There must be some connections fault on this new board or may be the another board is not working too.
Posted on Aug 15, 2008
    Genius:
  • 2,028 Answers
Was the board new or used?
  • Ryan Rogers
    Ryan Rogers Aug 15, 2008
    Also, what was the original problem that needed the board change?
Sir my korg x50 been dropped once and now it affected the program sounds acting weird..the program sound dont play the actual sound now.. please help me how to solve sir please,,,,
If you don't know how to repair electonic devices, you should look for a local repair service. No magical way to help you to repair a broken Korg
Aug 29, 2015 | Korg X50 61 Key Synthesizer Keyboard
Can somebody post the PA800 Diagnostic Menu Command
The details are highly confidential and have only ever been released to engineers under Non Disclosure Agreements, who work closely with Korg in the design process. If anyone tries to tell people about it on the forum then a breach of an NDA has occurred and whoever did it could be sued by Korg. The person posting those details could have their account on the forum suspended.
Please understand that there are very good reasons why Korg want to keep those details confidential. The functions were designed for use in the factory when the keyboards are manufactured. Two of the functions can completely wipe the internal SSD and the boot EPROM rendering the complete keyboard unusable. One of the circuit boards would have to be returned to a factory for the chips to be re-initialized using specialist hardware plugged directly into the CPU board. The necessary hardware to re-initialize the SSD and Boot EPROM is not even available to Korg service centers.
If you are someone who has discovered the way to access the system diagnostic menus, then there is a high risk you will completely trash your Pa2x/ Pa800 etc, turning it into a "brick" that will no longer be capable of reloading the OS or factory data. Korg representatives have said to us several times that damage caused in this way is NOT covered by warranty. If two of the functions in the system diagnostics menus are used, then to get the keyboard working again, service centers will have to replace the complete "main board". This is the board which contains the SSD and boot ROM chips. You are looking at a repair cost of over $800 plus shipping.
Oct 24, 2014 | Korg Pa800 Synthesizer
Korg pa 800 gone dark
Sounds like your keyboard screen is going bad, You need to contact Korg and order one, you can do it yourself or they have authorized repair shop around your house.
Good luck
Jun 10, 2014 | Korg Pa800 Synthesizer
Factory reset korg pa1x ?
To factory rest on Korg pa1x you should take few steps and as a warning i have to say you will lose all your existing setting and data.
First download the operating system version 3:01 into four floppy disks. you can find it for mac and PC versions.go to http://www.korgpa.com/support/discontinued-products/korg-pa1x-pa1x-pro.html
Second: if your Pa1x has Hard drive transfer the factory resource file from the above link into hard drive.otherwise you need to copy factory resources to FDDs again.
Third: turn off the Keyabord and insert the FDD1 into floppy drive. once you turn the keyabord if you press intro instead of OK it will wipe all the OS and setting on your keyboard and then start installing fresh Operating system.
Fourth: turn off and on the keyboard. then go to this and go to utiliy and find your HDD and load the factory resource. I mentioned if you don't have hard drive then go to FDD and insert the FDDs for factory resources and load them one by one. then turn off and on the keyabord.
All done.
Regards
Arash Armand
Sep 04, 2013 | Computers & Internet
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
Hi i got the korg pa50sd when i swith it on it shows me korg pa50sd boot loading files then this goes off, still the light on display is on but blank display with nothing on it ,. i was trying to find any...
NOT a fuse... thaat person knows nothing. There is something wrong for sure. Check if one of the buttons or keys MIGHT be stuck down (depressed). Sometimes the units check that all the control buttons are up and they don't really tell you why they fail to start. Beyond this a repair shop is in order.
Jul 11, 2011 | Korg PA50SD Pro 61 Key Keyboard Bundle
Every 3rd key is "touch-insensitive"
It's a mechanic problem, the plastic &/or the circuit under the keyboard keys should be cleaned and/or changed.
Sep 07, 2009 | Korg X50 61 Key Synthesizer Keyboard
Macbook Pro goes from gray apple screen to black
Try booting into single user mode by pressing Command+S while booting. You should then be at a prompt. Type in:
fsck -f
and press Return. Let it run and see if it corrects any filesystem issues, then reboot when it's done.
Apr 25, 2009 | Apple MacBook Pro PC Notebook
Korg triton Touchview screen not working properly
The Korg Triton touchscreen has two main parts - The LCD screen and the touch overlay. Between the two is a type of gasket. It is really just an adhesive, but it does help keep out moisture and dust. If you were to remove the screen, you could separate the two parts, clean it and use double-face tape or glue to reattach. You can also get a replacement LCD screen, touch overlay or touch-LCD assembly from a number of places on the internet. They are not cheap, unless you purchase a generic touch overlay or LCD and retrofit.
As for repair in your area... try contacting Korg at http://www.korg.com and look for authorized repair centers.
Jun 23, 2008 | Korg Legacy Collection
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
