Question about Refrigerators
Need a compresor - Refrigerators
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly,
Without a model number..... my best guess at your replacement compressor.... is here:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-COMPRESSOR-item-number-AP4514660.aspx
Thanks for choosing FixYa,
Kelly
Posted on May 24, 2011
Maytag mbf254h compresor will not shut off
You need to replace the compresor relay, this is the problem
May 15, 2010 | Maytag MBF2254H Bottom Freezer...
You need to replace the compresor relay this is the one that is stuck.
Mar 28, 2010 | Maytag MBF2254H Bottom Freezer...
I HAVE A PIECE OF EQUIPMENT THAT RUNS AT 75 PSI. I NEED TO BUY A COMPRESSOR THAT WILL HAVE A DUTY CYCLE OF 50%. HOW CAN I SELECT WHAT SIZE COMPRESSOR I NEED?
That is an extremely high pressure. I would firstly check to make sure that THAT is what you need, then MOST compressors have a regulator where you can adjust the pressure required.
It is not so much the pressure you need as the STORAGE of air that you need for a pressure that high. MOST tanks are around the 20 or so litre. To utilise a tool requiring the pressure of 75PSI I suspect you would need a tank of somewhere around the 2-300 litre size or maybe even bigger. But first just make sure that you DO need the 75PSI you mentioned.
Feb 10, 2010 | Air Tools & Compressors
Compressor low pressure triped
If the compresor, overheats, then compresor it's not good, make sure that there is a safety cycle on. Explain: there should a click when compresor starts if you hear a click again within 30 secs. is a confirmation that the compresor has weak coils, and needs to be replace. If this is not the case, make sure you are not using an extention cord to run this unit, maybe wire are overheating.
Jan 06, 2010 | Heating & Cooling
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 | Freezers
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Fridge freezer not working/power ok,
If the compresor is very hot and won't start,the clicking you heard is the overload at the compresor that goes on & off beacause the relay ,that makes the compresor start is bad or the compresor is bad ,if you know how check the compresors coil if not try replacing the relay with a same replacement(no more than $20 or $30) if still won't start the compresor needs to be replaced.
Apr 24, 2009 | Refrigerators
No cooling,compressor comes on and shuts off quickly
All refrigerators compresors have a relay and a overload thermal protector ,both are located on the side of the compresor behind a black plastic cover atached to the compresor with a metal clip(or just the cover snaps in on the compresor).Unplugged the fridge ,pullout the cover and you'll see the relay and the overload replaced them (no more than $30).If this doesn't solve the problem you have a bad compresor, wich is a much more expensive job.
Apr 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
Turns on...clicks every few minutes....never gets cold
It looks like the compresor is trying to start and goes off on overload ,it could be a bad relay or a bad compresor.Try first replacing the relay located on the side of the compresor under a black plastic cover(ALWAYS UNPLUGGED THE FRIDGE BEFORE DO ANY WORK) if that does not work you need to replace the compresor.
Apr 09, 2009 | Danby DAR482BLS Compact Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
