Question about Western Digital Wd Elements Se 1tb Portable Black Wdbabv0010 USB 20 Hard Drive
The device cannot be read by my computer - Western Digital Wd Elements Se 1tb Portable Black Wdbabv0010 USB 20 Hard Drive
  • Western Digital Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 24, 2011
Bluetooth option doesn't show in my laptop
You can find the Control Panel by clicking on the "Start" menu and selecting "Control Panel."
Click on the icon that reads "Hardware and Sound." Then, select the tab that reads "Bluetooth Devices."
Click on the "Add" button. This will put your computer in "Search Mode."
This means that it will search for any compatible Bluetooth devices in the area.
Put your Bluetooth device in "Discovery Mode."
This can be done by pressing and holding the button on the side of the device.
This will cause the device to send out a signal that will be received by the laptop computer.
Select your device from the list of found devices on your laptop.
Once this is done, your laptop and Bluetooth device will be permanently connected as long as they are both turned on.
hope this helps
Sep 21, 2012 | Computers & Internet
My computer wont read my sdhc 4g sandisk card
Not all card readers, devices and computers can read the high capacity format, however. If you are getting a read error, it could be that your reader is not SDHC compliant. If this is the case, your device should read 2GB or smaller cards, but respond with an error for larger capacity cards.
Apr 24, 2012 | SanDisk 4GB microSDHC Memory Card
My laptop reads "operating system
When you "boot" your computer, it tries to read from all the "bootable" devices:
* diskette
* CD/DVD
* disk-drive
* USB memory-stick
for which the BIOS SETUP has listed as "bootable" devices.
If it cannot read the "boot" information from _ANY_ of those devices, it reports "operating system not found".
So, enter BIOS SETUP, and ensure that your disk-drive *IS* "detected" (i.e., not "dead")
and that it is "enabled" as one of the boot-devices.
The most-likely (and most-disasterous) cause is that your disk-drive has "died",
and the Windows operating system could not be read from the device.
Take your computer to a qualified technician, for professional trouble-shooting.
If you have the original "System Restore" set of CDs, take them, too.
Jan 15, 2011 | Microsoft Computers & Internet
Parts of computers and its function
Computer: A machine that processes information and performs computations.
Tower or CPU: The "box" or case that holds the parts that make up a computer: CPU, hard disk drive, floppy drive, memory chips, power supply, interface cards, etc.
CPU: Central Processing Unit, or "brains" of the Computer.
Monitor: An output display device (looks similar to a TV) in a computer system. You see information on the monitor's screen.
Screen: The viewing area on a monitor or the information or image displayed.
Disk Drive: A device that reads data from (input) or records data onto a disk for storage (output).
Hard Drive: The main device that a computer uses to store information. Most computers come with a hard drive, called drive C, located inside the computer case.
CD-ROM: ROM means Read-Only-Memory - you can only "read" information, not save. A CD can store a large amount of data including documents, photographs, software, and music (about 20 songs)
Mouse: A hand-held input device you roll on your desk to point to and select items on your screen. When you move the mouse, the mouse pointer on the screen moves in the same direction.
Speakers: Output device that produces sound and music when connected to the computer. Speakers come in different shapes and may even be in the monitor's case.
Headphones: Output device for listening that is held over the ears by a band worn on the head.
Microphone: Input device in which sound energy is changed into electrical energy for the sending or recording sound (your voice).
Scanner: Input device that reads copy as an image and digitally records the image.
Jul 05, 2010 | Dell Inspiron 530 Desktop Computer
NO READ COMPUTER
Try plugging this device into another computer. If it still doesn't work, the device has died.
If it does work, the computer that won't read this device probably has usb driver issues or usb hardware failure.
Jan 13, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
What is ebook for and what can u do on it
An eBook is an electronic version of a print book that can be read by using a personal computer, mobiles, tablets or device special made for reading e-books like the e-reader.
You can easily download your favorite books and read it anytime and anywhere in your mobile or tablets.
Dec 30, 2009 | Mach Speed Trio Portable MP3 Player
The MP3 isnt read on the computer
if u have a installer cd with the device then
please install the driver then plug your device
in the connectivity cable.plug your device on the cable.
Dec 28, 2009 | Coby MP725Digital Media Player
I can charge my mp3 player but my computer dosn't read my usb ports,do you know why?
If your Computer can read other Devices such as USB Memory Sticks, that means that the the MP3 Player requires some drivers or needs some software. If your Computer cant read any USB Devices, then you need to install the USB Drivers for your computer.
Oct 13, 2009 | Systemax Ascent RTS A14 (980796) PC...
Computer wont read mp3 player when connected
is the USB device enable in the computers bios
does any usb device detected by the computer.
or
go to the control panel/system/device manager
does it show usb devices
Feb 25, 2008 | Samsung YP-K3 MP3 Player
Western Digital Wd Elements Se 1tb Portable Black Wdbabv0010 USB 20 Hard Drive Logo
165 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
