Question about Kitchen Ranges
Displays "F7" and a continuous
  • 17,970 Answers
If your Maytag range displays the "F7" error code, it means that the programmed fault error 7 occurred with the range. Luckily the error is easily fixed in most cases and requires no new parts.
Identification:
Once the error appears on the range it is usually followed by seven loud beeps to represent the number. Clear the error by holding a button down for a minute. The LCD will flash and the code will disappear.
Effects:
The most common cause of the "F7" error is a stuck button on the LCD panel. Look around the range control panel and examine to see if any buttons appear pushed in, stuck or out of place.
Prevention/Solution:
Take a damp rag and light wipe around the buttons to clear out any grease, food particles or sticky substance that may have built up around the button. Attempt to use your range and see if the error appears again.
Considerations:
If the error continues to appear, there could be permanent damage to your electronic range control. Contact your Maytag dealer for warranty information and replacement parts.
Keep us updated.
Posted on May 24, 2011
  • ZJ Limited
    ZJ Limited May 24, 2011
    F7 means stuck keypad (stuck keypad may mean relay is turned on)
    Determine if problem is with the Key Panel or Control by:
    a. Pushing CLEAR/OFF pad.
    b. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
    If code recurs, problem is in the control. Replace control.
    If code does not recur, problem is with the Key Panel.
Was low temp roasting of ribs in Jenn Air JMW9530AAB convection oven. Heat webt ofand stove started to beep and displayed "-F7-". Cancel failed to do anything. Shut power off and when turned...
The electronic control may not be set correctly. If the control is not programmed correctly the oven will not start and you will usually hear a series of beeps instead of the microwave starting. See your Use & Care Guide
Aug 09, 2008 | Jenn-Air Kitchen Ranges
Oven beeps and displays F7. Hit stop/cancel, starts up again in about 10 seconds
Hi cpwdavis,
The F7 failure code shows a Function key shorted or stuck. To resolve this problem, you need to replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Sep 22, 2011 | Jenn-Air JES9800A Electric Kitchen Range
I need to install win xp on hp 540 and ineed to know if i have to configer from bios or i need win xp sata support OS?
Befor installation you need to follow the following steps
1. Start your laptop and press F10 continuously to go to BIOS setup.
2. Go to "System Configuration" -> "Device Configurations"
3. Set "SATA Native Mode" to Disabled.
4. Start the installation while keeping a finger on "F7" key.
5. After some time there will be continuous beeps.
6. Remove your finger for sometime and then continuously press "F7" key till the beeps are repeated. This is done to disable your BIOS ACPI.
7. And then do you normal Xp installation.
8. This should do
Jan 08, 2011 | HP Jornada 540 Pocket PC
The oven keeps beeping and displays "F7" as an error message.
Hi
Thanks for using FixYa. Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC). Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Jenn-Air JMW9530C Stainless Steel Oven
''F7'' Error Code
HI. This is the result of a failed function key. This is an integrated part of the main control board. Unfortunately, this is not repairable, and the main control board will need to be replaced, asap.
Dec 20, 2009 | Kenmore Ovens
I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
F7 stuck keypad
Stuck keypad may mean relay is turned on.
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
Jul 30, 2009 | GE JTP45 Electric Double Oven
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 30, 2009 | GE JTP20 Electric Single Oven
F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Jun 30, 2009 | GE JTP45 Electric Double Oven
The lcd scrren on my range displays F7 in red and flashes d6 in g
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/
Dec 13, 2008 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
485 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
