I purchased cd-r part#3202 4581 qty 100 52x 700mb 80 min.these will not record in my cd burner but another memorexcd-r 74 da will what is the differance between the cd's please contact me at [email protected] thanks
  • 2 more comments
  • jjvance2 Aug 15, 2008
    if u did not know what the diff is why offer answer? please need more help as to solution to why and what to look for in any future purchase of memorex cd's
    both cd's purchased are memorex on 74 min version will record 80 min wont both are cd-r
    enen though both are made by memorex and both are listed for audio recording there is nothing to look at that will give me any advice as to if item will work in my recorder
    no the solution is that i can ony but one at a time to see if thay are compatable with my burner
    Master:
  • 521 Answers
Its the issue of the writing speed. so some cdr works while others dont.there is no particular solution to solve it as the unit is perfect.its just the way it comes.
Posted on Aug 15, 2008
  • 6,487 Answers
Writing speed is the difference between the two adn some burner don't support that type of writing speed, that's why the other CDR work with your burner......
Hope thta helps........
    Scholar:
  • 53 Answers
There will be compatibility issues with few brand DVDs. Like most of the HP laptops can't read Memorex disks. That is compatibility issue.
Once check with another brand disks for this issue. If the issue occures withone or 2 brand disks, then it is compatible issue.
Once contact the manufacturer of the drive to check for CD/DVD drive firmware update.
  • Anonymous Aug 17, 2008
    Just to let you know, that there is compatible issue with the Memorex DVDs with HP drives and laptops.
    You can contact HP and ask them whether u can use Memorex brand disks.
    You will get the below answer:
    It is not compatible with Memorex brand DVDs.
    Make sure you are using 2X speed while creating the discs.
    I suggest you to use the DVDs from HP, Philips, or Sony.
  • 10,594 Answers
Might be difference of Writing Speed ..like 52x ..I'm not sure about this. Just giving you an idea.
  • Shahid Electronics
    Shahid Electronics Aug 15, 2008
    Being a tech-person I know, If Optical Lens has layer of dust on it, decrease its efficiency of reading and writing. Please check and try to clean its lens. It might help you to complete the task.
SOURCE:
Am in process tranferring vinyl to cd using sony compact disc recorder and not computer,ran out of audio discs last week purchased some verbatim discs high speed rw but will not work on my machine can you...
Hi raymackie265
You are right , don't use cds for computer ( cdroms ) but well audio cds . Pay attention to this point when purchasing new stuff . Regarding the issue with cd-Rw , it's a compatibility issue with your Sony device and you need to check if the recorder will accept CD-RWs . If yes ( and it should be yes ) , try to find lower speed discs but you need to find audio cds . I ' m using a Pioneer recorder and it works fine with any kind of audio cds , not with cdroms .
Best regards ,
fanaudi .
Aug 30, 2011 | Verbatim 10PK CDRW 80 MIN 700MB 4X12X...
When I put the CD in to record a cd I recorded, it is coming up, no disk
You don't mention what device we're talking about. Blank media must SAY "CD Audio" on them.
Aug 01, 2011 | Maxell CD-R 80 Minute 700MB Media...
Do i use 12x/700MB/Mo/ 80 min to record on
You could try and see. But the blank media MUST say it's for music or audio.
Feb 07, 2011 | KLH CDR2000 2-Disc CD Recorder
How do I unlock a never used maxell CD-R
If this is a CD case, take the plastic wrap off on the outside(if any), then gently bang the case on a wooden surface,then lastly, push down on the plastic case, twist it & it should open.
Jun 10, 2010 | Maxell CD-R 80 min. 700MB Music Recordable...
Mp3 files will not burn
No imation brand is known for problems but maxell usually work great i suggest cleaning the cd burner try compressed air can spray out the cd burner with the door open you may have dust on the laser lens...
Feb 05, 2010 | Maxell CD-R 80 Minute 700MB Media...
I purchased a pack of Memorex CD-R rrecordable 52X 700MB 80 min. discs from Staples and I was told I could use these to transfer pictures from my drive c. When I put the CD in to the drive D it asks me to...
Cd-R does not need formatting. They are ready to burn. There is probably a problem with your cdr drive.
A cd-rom drive is not a burner.
Are you sure you have a burner and not a cd-rom?
If you do have a burner, try another few disks. If it still says insert disk then your burner has crapped out.
Aug 12, 2008 | Computers & Internet
Nakamichi cd45z
The CD45z does not play MP3's ....Nak is about SQ ...since MP3's are poor quality ...this doesn't fit with what Nak is about.
Mar 03, 2008 | Nakamichi CD-45Z CD Player
Can't burn cds
check your compilation, it is possible that you are trying to burn more data than you can write to a blank CD, in which case it will ask for a cd with the right capacity. 80 min CD-Rs can have 700MB written to them. if you are trying to write more than this the software will reject the blank as not having the right capacity.
Sep 29, 2007 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
53 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
