Question about LG LHD459EL Dehumidifier
My dehumidifier freezes up and never gets the humidity to the setting I have established. Do you think it is worth repairing??
    President:
  • 2,080 Answers
If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room is probably just relatively low and you probably have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room. Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where it is warmer.
I don't believe you need a new dehumidifier. Just try a few of the simple tips above and see if it works any better and stops freezing up.
Hope that was helpful, thank you and good luck.
Joe.
Posted on May 24, 2011
Testimonial: "Thanks, I have put it on a 2 hour on off cycle and it appears to be working well"
New Whirlpool gold dehumidifier last summer. Used since then. It still runs (fan) but no water is being taken from the air. I clean the filters, looked at coils, they are like brand new. I hate to give up,...
Kim, it may simply be a case of the humidity extraction level being set to HIGH. Lower it to 35%. If it's an analog unit (No LED Display) turn the humidity extraction knob to Maximum. More often than not, this will solve the problem. If it doesn't the humidity sensor may need to be replaced.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The unit turns on, but indicates the room is at the lowest humidity setting (30%). Therefore, it won't turn the compressor on because it believes the room has reached the correct humidity. Any...
The humidity sensor or the humidistat is probably the problem...
Replacing these can correct the problem, but may cost more then the dehumidifier is worth...
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 09, 2010 | Amana D565M Dehumidifier
I just get a dehumidifier it was on all night and the bucket its dry u think theres something wrong with it and whats the % that i have to set it up
% is the % humidity you want.
This is a DEhumidifier for to take water out of air for moist areas.
Usually a setting of 50% or 60% is dry enough. If it is freezing outside, inside of home is probably alreadt below 50%.
If you place in basement below 60 degree, will freeze up. Place over floor drain or in tub and leave off overnight.
Dec 05, 2009 | Goldstar DH504EL Dehumidifier
What are the settings (humidity)from 40 upwards on my micromark ? . Is the lower setting to take out most moisture ? Thank You
40 is 40% humidity in room - that's really dry.
For moist area you usually want 50 or 60%.
Dehumidifiers are for damp areas. If temp ouside is below freezing, inside house is probably already too low.
Dec 01, 2009 | Dehumidifiers
What # should I set humidity on/
Perfect humidity is 50% according to conventional wisdom. As far as a number to sit it on ... well you will have to refer to the owners manual.
Dont have one --- contact Haier. I found them to be very helpful, particularly when I wanted a no longer in production machine manual.
It might be that the air you are dehumidifying is already lower than you think. You could measure the humidity independently.
Oct 19, 2009 | Haier 45-Pint Dehumidifier
Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
Sep 01, 2008 | Dehumidifiers
Humidity reading is 16% when actual humidity is 46%
Running a dehumidifier when the ambient temperature is to low will cause freeze-ups. Also running it when the dew point of the moisture in the air is to low will cause it to freeze up when you set it to low which would be a higher number on the set point.
The hand written number on the probe casing is probably a quality control inspector number.
May 04, 2008 | Danby DDR586R Dehumidifier
Humidifier that never shuts off.
I am having the same problem with mine and it has started freezing up for no reason. Did you get any answers
Nov 20, 2006 | GE AHG40LA Dehumidifier
LG LHD459EL Dehumidifier Logo
254 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
