Question about Hitachi NR90AD 3 - 1/2'' Clipped Head Strip Nailer
My older style Hitachi NR90AD still works OK but always leaks a little air out of the very top of gun. I took the head off, cleaned, and oiled but still leaks by.
    President:
  • Hitachi Master
  • 1,388 Answers
Over time debris enters the gun and scratches the metal and plastic surfaces where orings seal against. These scratches will allow air to leak past. Remove the head and pull out the head valve. Examine the metal surface with magnify glass where the headvalve oring makes contact. Remove scratches with 400 grit paper. The surface must be smooth and the oring must seal snugly. Apply silicone paste lube on all surfaces and orings (available at Lowes in the plumbing department and swimming pool supply). Also check for scratches around the body of the gun were the cylinder plate is installed around the cylinder. The gun will not work properly will small air leaks. Remove nails and listen for leaks thru the nose of the gun. Repair as needed. Good luck with your gun.
Posted on May 27, 2011
Bought hitachi nr90ad nail gun and it isn't firing right..what exact size nails should i get ( as in 35,33,or 30 degree nails)
Use 34 degree, paper collated, clipped head nails. They were always the most common strip nails years ago as Senco, Paslode, and a number of other nailers used them.
Jul 25, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Just replaced o rings and piston bumper, but gun still leaks air (out of nozzle) and wont fire at all
Air leaking thru nozzle (where nail exits ) can be caused by two issues. Air leaking past valve rubber at top of cylinder where headvalve seals when under pressure. If leaking at valve rubber seal the piston will usually be pushed down if there are no nails in gun. If the driver stays up while leaking then problem is at cylinder plate. This plate has two orings that seal air pressure. On seals against the body of gun and the other seals against cylinder. Leaks can occur if body of gun is worn, warped or has scratches where oring makes contact. Also look closely at the plate for crackes. Replace parts as needed. Good luck
Feb 27, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Air is continually running but no presssure is building up so the drive pin never resets in order to shoot the nail
Remove head and check seal between headvalve and cylinder. If seal looks good, just remove head parts and clean/lube. Also clean/lube orings between cylinder and body of gun.
Sep 23, 2010 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Hi, i got a hitachi nv45ab and My nailer leaks air out the back
Hitachi nv45 series is the most popular line of nailers amoung professional roofers. There are three areas that develop leakes. Leak out head vent indicates cylinder stuck in lower position or headvalve worn. With air connected, gently rap head of gun against rubber mat to move cylinder to position. (Use caution not to damage head). If this action works, gun needs cleaning internally or lack of oil. If air still leaks out vent remove head and examine valve in head and replace as needed. Check that cylinder moves freely up/down (travel aprox 1/4"). If cylinder is hard to move pull cylinder and clean replacing orings as needed. If leaking around trigger, remove rollpin and trigger and check nylon ball for pits and replace as needed. If leaking around base of gun check for loose bolts and/or worn gaskets. Remove nail canaster to check feed piston gasket and screws. Good luck with your repair and post again if you have other question.
Aug 04, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Air leaking aroung the trigger assembly from my Hitachi NR83A
if you took the trigger apart the part that you unscrew has a nylon ball and a black rubber ring you should check them and make sure that you didn't loose them when you took it apart,if they are there, then you need to service the gun, and after you clean all the moving part and you put it back together, it may still leak from the top,Take a rubber hammer and give it a good hit,now not to hard, and it should seal
Apr 27, 2010 | Hitachi NV45AB2S Coil Roofing Nailer
My nailer leaks air out the back my,roofing nailer wont hold any air
Hitachi nailers are built on very close tolerences. Dirt /grit will prevent cylinder from resetting causing air to leak out of top of gun. You can force a reset by striking the gun head first against a rubber mat. Only one or two hits because you could damage the head. If the gun does not reset you will have to take apart and clean out grit and replace orings as needed. Good Luck and post again if you have other questions.
Mar 10, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi NV45AB coil nail gun is leaking air from top of gun
the top!! o-ring inside of thr top plate is bad you need to remove the plate /dissasemble and replace the o-ring
Jan 21, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi nail gun nr90ad leaks from trigger when air hose is connected
Orings, they have to be replaced every few years. Warranty does not cover them.
Any Hitachi service centre should stock them. Or find your model on Ebay:
http://shop.ebay.com/i.html?_nkw=hitachi+o-ring+kit&LH_IncludeSIF=1&_arm=1&_armi=0&_armm=20&_ruu=http://shop.ebay.com/i.html%3F_nkw%3Dhitachi%2Bo-ring%2Bkit%26_arr%3D1&_rdc=1
Hope this helps!
Thanks
Jan 20, 2010 | Hitachi Air Tools & Compressors
What is the angle of the nail we use with this nailer
if thats a hitachi nr90ad, then you should be using 30 degree paper taped clipped headed nails,, never use plastic or wire collated nails in that gun,, some boxes might say 30 up to 34 degree and thats fine, also in a lot of areas clipped headed nails are no longer code, so they made the nails full headed, the head is just off set,,
Dec 04, 2009 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Hitachi NR90AD 3 - 1/2'' Clipped Head Strip Nailer Logo
169 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Roger Paull III
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
