Question about Kitchen Ranges
The control panel on our frigidaire ceramic cooktop range (FEFL67GCA) came loose on bottom right corner. Still works, but wiggles...
  • 1 more comment
  • Cheryl Leu May 24, 2011
    No... I went to turn the oven off by pressing the button on the control panel. But instead of the oven going off, the whole panel gave in on the lower right corner. (I did get the oven off though by pressing again).
  • Cheryl Leu Jun 06, 2011
    I was hoping for advice on how to fix the problem, not finding the diagram. I found that myself, too. We got the thing rigged back in place anyhow, and my husband was upset that I wasted $12.
    I found that diagram, too. But that was all I could find, so I wrote to you for more help on fixing the problem. Well, we got the piece rigged in on our own. However, we are sad to spend $12 for nothing.
  • 1,998 Answers
This is the diagram to your unit where the control is seated there are four screws that hold the control in place the control is noted in the diagram as part number 20 click this link http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0703057-00001.png you would need to remove the screws from the rear of the range in order to access the screws on the control if you have any further questions message me back I await your reply Thanks Rick
Posted on May 24, 2011
  • Kitchen Ranges Master
  • 2,098 Answers
Hi Cheryl,
If I'm not mistaken you are talking about the "control knob" of the range which was already loose internal thread due to wear and tear and made it wiggled upon turning on. You may click the link below for the genuine parts replacement.
FEFL67GCA Control Knob
You may pull-out the existing knob by applying a little pressure on it and you may install a new one.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
Error Code E0 39 after replacing induction Control module. Our Range is Frigidaire CPCS3085LF, apparently the module is not talking to the panel. is there a fix?
Execute following sequence to force cooktop reconfiguration (Be sure the good ESEC20 UIB is installed into the cooktop)
1-Put all rotary control to the first detent position clockwise (1 o'clock).
2-Put all rotary control to the first detent position counterclockwise (11 o'clock). The system should then reconfigure, showing walking dashes on the cooking zones displays.
3-Put all rotary controls to "Off" position. There should be no more error code and the cooktop is ready for operation.
Frigidaire Range Stove Oven Surface Element Board 318329620 Frigidaire Range Stove Oven Oven Control Board 318347100
Jun 12, 2016 | Frigidaire Kitchen Ranges
Frigidaire ceramic stovetop burner not working
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
Aug 30, 2014 | Cooktops
316065306how many watts to run this range
Hello friend, thank you for your post!
I understand that you are searching for the wattage on your Frigidaire range. In order to provide you more information I would need to have your model number. You can locate your serial tag (which lists your model number) on the outside of your cooktop base possibly on the edge or bottom under the unit. Once I have that information I can further assist you. I look forward to your response. -Matt
Aug 19, 2014 | Frigidaire 30 in. Electric Ceramic-Glass...
Scratches ceramic stove top
Good Afternoon Friend,
I understand that you have scratches on the ceramic stove top of your Frigidaire rage, model# FEF366. Small scratches do not affect cooking and will become less visible with time. To prevent any further scratches, make sure you do not use any abrasive cleaners. These can scratch your stove top even more. Try not to use cookware with rough bottoms. These can mark or scratch the cooktop surface. Try not sliding any metal or glass across your cooktop. This includes sliding your pans as well. Coarse particles such as salt or sand between cooktop and utensils can cause scratches. Be sure your cooktop surface and bottoms of utensils are clean before usage. I hope this is helpful.
-Best Regards-
WP
Jun 26, 2014 | Frigidaire FEF366 Electric Kitchen Range
Any way of repairing chip in cooktop
Either leave it as it is or replace the hob as a spare part is available for most ceramic hobs.
Dacor ETT304 Cooktop Parts
I have no idea which country you are in so this site will start you off looking for spares.
May 22, 2017 | Kitchen Ranges
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
Frigidaire FEFB78DCD range wont heat but display and lights work
you need to check all the wiring.the main control board should be replaced.
Feb 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
SMOOTH COOKTOP DISCOLORATION
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff really works!!
Aug 12, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
