Question about Cameras
I went camping for the weekend and it worked perfectly fine until this morning, i turned it on and the back light would not work. this happened last year and it just magically started to work again but now its not and im not sure what to do. help please?
    Sergeant:
    Champion:
  • 214 Answers
Hi would you provide your name of camera model? then I could answer. Thanks and best regard!
Posted on May 24, 2011
Dominic 2820 won't get cold
The Dometic RM 2820 was working last night. This morning it was not cooling and now the front panel and interior light are not working. No smell of ammonia. Any help with this challenge? Thanks,
Jun 11, 2013 | Dometic Classic Rm2820 2 way
Put new (rebuilt) starter on last weekend, this weekend drove it for 3 hours, parked it, 4 hours later went out to go somewhere and not even a click, battery is good, headlights are on, battery cables are...
Bummer. Sometimes rebuilt starters are not actually rebuilt, but repaired. this means they fixed the issue, but did not replace bushings, brushes, etc...
try hooking up a wire to the actuater terminal of the starter (usually the small one at 2 o'clock position) and connect test light to it an ground the test light. Run this wire inside the cab so you can see it...When you turn to start, this light should light. Run vehicle until problem happens again and if the light illuminates, the focus is the starter, if it does not, you need to look at the entire circuit. Look carefully at neutral safety switch and connections..
Nov 02, 2010 | 1984 Dodge D150
Konica 7020 error code f-26-2
Says that it is a PCL connector problem. Look at all of your connections and make sure they are ok.
Jun 24, 2010 | Office Equipment & Supplies
I have 1998 Chevy Silverado with over 200,000 miles. One morning I started it up just fine, backed out of the drive way, and it just died. I turned the ignition to off, and turned it back on and parked it....
Check your battery terminals. They may be corroded or just loose. If you get it running again have the battery and charger tested at an Advance or Autozone.
Hope this helps.
Rich
Aug 19, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Same exact thing happened to me today with my 06 Odyssey !!!!!!!
the main switch that controls all the windows is on the drivers side it will allows the drivers window to work then allow your brain into thinking that its fine no its not always fine change it your problems will go away. its the master/main switch that is why the two back windows does not work, they does not always go bad at the same time.
Aug 19, 2009 | 2002 Honda Odyssey
A/C quit working
these cars have a switch that shuts down the compressor when it is overfilled. (to much pressure) take it to a shop and have them correct it. There is no way to do this yourself with out a set of gauges and they are more expensive than what the shop would charge to do it
Jun 21, 2009 | 2001 Ford Focus
Starting problems - 93 VW Polo - Creamy white substance in carb
If you pull out the dipstick you will find this is also white, which is water in your oil. More than likely cyllinder head gasket.You will probably find it in your water bottle as well
Mar 02, 2009 | 1993 Volkswagen Golf
Open Questions:
Cameras Logo
18 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
